wiring on 1994 pickup - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-13-2008, 04:19 PM   #1 (permalink)
View spinman's Photo Gallery
I'm adding power locks and windows and I don't see any hole in the body to pass wiring through. Any special place to drill a hole?
spinman is offline   Reply With Quote
Old 09-13-2008, 04:31 PM   #2 (permalink)
just a nobody
From where to where are you passing the wires?
N.E.O.
Old 09-13-2008, 04:34 PM   #3 (permalink)
There is a hole in the hinged edge of the door but no corresponding hole in the door frame. I suppose I could drill a hole near the lower hinge. The wires are going from the new power door locks and window actuators to the controls I will mount under the dash near the steering colum/fuse box.
Old 09-13-2008, 04:43 PM   #4 (permalink)
just a nobody
I would look at a truck that has power door lock and window to see where it is located at. And also pickup some conduit from the wrecking yard, makes it look factory.
N.E.O.
Old 09-13-2008, 05:12 PM   #5 (permalink)
View farmboy191's Photo Gallery
i work at a mobile electronics shop and i put those things in all the time here is where i went with my wireing
there was a pre existing hole in the door and for the inside ones i took off the kickpanel and drilled a hole where i could get the drill and put a gromet on it to protect the wiring. also i havent put power windows on yet
farmboy191 is offline   Reply With Quote
Old 09-18-2008, 12:54 AM   #6 (permalink)
Thanks for everyone's help. I've got the wiring installed with rubber boots between frame and door. I need a power connect that is always on and one that is on with IGN. I have these two leads to my radio but that is downstream of the fuse box. Any suggestions where to tap either at or ahead of fusebox??
Old 09-18-2008, 09:35 AM   #7 (permalink)
well if you are handy with car electronics you can take off the dash panel on thedrivers side and get power and ign right from the ignition harness
i forget what the wirecolors are but if you have a multi meter you can test it out
