U-joint help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-13-2008, 06:13 PM   #1 (permalink)
FoxRacin17's Avatar
View FoxRacin17's Photo Gallery
U-joint help
i need to get my old u-joints out of the driveshaft. i tried using a c-clamp to push them out and it bent the friggin clamp. any ideas?
Go Gators!
FoxRacin17 is offline   Reply With Quote
Old 09-13-2008, 06:30 PM   #2 (permalink)
just a nobody
A big hammer and a small hammer worked for me.
N.E.O.
Old 09-13-2008, 07:26 PM   #3 (permalink)
denniswoo's Avatar
View denniswoo's Photo Gallery
USA u joint
2lb hammer and 8 oz ball peen,like new echo owner said.sit the drive shaft in a vice or on a red brick end hanging over and pound them out.if you had a press that is the ideal way to do it.
denniswoo is offline   Reply With Quote
Old 09-13-2008, 08:28 PM   #4 (permalink)
slacker's Avatar
View slacker's Photo Gallery
bench vice , and sockets always work for me ...
slacker is offline   Reply With Quote
Old 09-14-2008, 01:36 AM   #5 (permalink)
just a nobody
That works too, but you will need a very big vise.
Been there done that.
N.E.O.
Old 09-14-2008, 08:58 AM   #6 (permalink)
Ex-Master Diagnostic tech
View hevster1's Photo Gallery
Sometimes they sieze and a press is the only way without damaging the shaft. Take it to a driveshaft shop.
Ex Toyota MDT 28 years of experience. I still fix them daily by appt only. Written warranty-great prices. References available.
hevster1 is offline   Reply With Quote
Old 09-15-2008, 03:47 PM   #7 (permalink)
FoxRacin17's Avatar
ok, i took it to a guy and he did it and installed new ones for 40 bucks. well worth it.
however, i didnt know until after i took it off that you have to mark it so you put it back on the same way. if i did put it back on backwards (theres only 2 possible ways to do it on these trucks), will it make any difference? will it vibrate? will it screw anything up?
Go Gators!
Old 09-15-2008, 04:03 PM   #8 (permalink)
just a nobody
Some times it may, and some times it may not. Marking it is just a good practices, just in case if the driveshaft was balanced previously, it will still be. As it is right now, put it back on and drive it, if you feel vibration that you haven't felt before, rotate it 180 and see how it is.
N.E.O.
Old 09-15-2008, 07:34 PM   #9 (permalink)
FoxRacin17's Avatar
ok, well its smooth as silk now. wish i had done it sooner. i guess i just got lucky and put it back right. thanks for all the help guys. appreciate it.
Go Gators!
