22r wrist pin bushings - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-13-2008, 09:49 PM   #1 (permalink)
View wvyota's Photo Gallery
USA 22r wrist pin bushings
Has anyone put wrist pin bushings in there 22re truck lately I have a body lift looks like it will help on getting the oil pan off, Just wondering if anyone has ran in to any problems that I should know about.
wvyota is offline   Reply With Quote
Old 09-14-2008, 11:17 PM   #2 (permalink)
denniswoo's Avatar
View denniswoo's Photo Gallery
USA bushings
the oil holes have to be lined up in the bushings to rod.you press the old ones out and the new ones i would freeze them in your freezer take them out one at a time and quickly press them into the rod.you can also put the rods in your oven at 450 for about 25 minutes and put the bushings in that way but the freeze method is safer.heating you need a thick pair of asbestos gloves or similar types.you can cold press them in the rods but sometimes you will need a reamer to size them for the wrist pin.the machine shops don't charge much for doing this though might be cheaper in the long run.
denniswoo is offline   Reply With Quote
Old 09-14-2008, 11:30 PM   #3 (permalink)
just a nobody
Haven't heard about replacing wrist pin bushing in ages.
Having a body lift would be easier to pull the pan off, but working on the top end might not be fun.
N.E.O.
Old 09-15-2008, 07:11 PM   #4 (permalink)
Vicoor's Avatar
View Vicoor's Photo Gallery
Makes you wonder... Don't it
Don't talk about it, Just do it!
22RE, xtreme ported head, crane cam, cust manifold, MegasquirtII-Extra(full sequential inj/spark), 300cc inj, adj reg, supra fp, LCE header, W58, short throw shifter, 14lb flywheel, kevlar clutch, 4.10 gears &Truetrac, drop spindles...
Vicoor is online now   Reply With Quote
Old 09-15-2008, 07:49 PM   #5 (permalink)
just a nobody
Yep, that was the old school stuff, nowadays, just replace the rods.
N.E.O.
