If your engine is running that poorly, seafoam is not going to solve your problem, although it can't hurt. Suck the seafoam through the main brake booster line, slowly, and give it gas when it bogs, which it will. Pour half the can in your gas, suck the other half (8 oz. of it) into the brake booster line. Then let sit for 10 or 15 and then drive around like James bond with a smokescreen. Although you'll need to find out why it runs crappy. Give it all new ignition parts, and check the air filter, as the easiest ways to begin.
'93 Pickup 4x4 22R-E
