Replacing 22re head gasket - what else? - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 13 Old 09-23-2008, 11:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
A couple months ago, my old '89 (22re - 181k miles - 83k of those are mine over 7 years) started getting losing coolant and getting hot. Fearing the worst, I drained the oil and found it was contaminated with coolant. I went out and bought a new '09 Tacoma and it's been great.
The '89's been just sitting since; it was my first vehicle and I'd like to see her running again. I'm hoping that the issue is just the head gasket so I'll be removing the head for a better look.
Providing the head is in good shape, I'm considering the following tasks:
  1. replace head gasket
  2. replace valve cover gasket (needed to do this for a while)
  3. valve adjustment (also needed for a while)
  4. timing chain (might as well while I'm there, right?)
  5. ???
QUESTIONS:
1) Are there any other tasks I should be considering as this project progresses? Comments on my existing list?
2) Can anyone recommend decent parts (i.e. head gasket, timing chain kit) -- Toyota or other?
(Fel-pro gaskets were recommended by my father based upon his experience years ago.)
3) Recommend a vendor/website to order from?
I have the FSM PDF so I think I'm covered there. Any input on my above questions would be appreciated.
Nybbles is offline
post #2 of 13 Old 09-23-2008, 11:52 PM
denniswoo's Avatar
Quoted: 0 Post(s)
i would first check the front timing cover to make sure your timing chain has not worn through the cover,that is a common thing that will happen to these engines.if you find the timing chain rails worn down of missing look good down into the front cover use a good bright light.if you find the plastic rails are broken missing,i would pull the front cover before pulling the head and check for wear in the aluminum cover.i had the same problem with mine.i also thought a head gasket and pulled the head first dumb thing but i learned.i broke one head bolt trying to remove the head.thank goodness i managed to get it out after pulling the head.but the gasket looked like new and was a lot of work for nothing.hope this helps.
denniswoo is offline
post #3 of 13 Old 09-24-2008, 01:17 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Originally Posted by denniswoo View Post
i would first check the front timing cover to make sure your timing chain has not worn through the cover, ...
Thanks for the tip! Assuming that's all it is, I guess I wouldn't need to pull the head; I'd just need to pull the valve cover in order to investigate the guides, correct?
And if it that's what it is, it seems that I could replace the chain and guides with just the valve cover and timing chain cover off, right? Still no need to pull the head?
Nybbles is offline
post #4 of 13 Old 09-24-2008, 09:33 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 177 Post(s)
Correct. You can also pull the oil pan and look for pieces of the guides.
Correct. You do not need to pull the head to R&R the TC. Just don't for get the bolt hidden under the top TC sprocket that goes thru the head into the TC cover.
And it's a good idea to R&R the H2O pump and maybe the oil pump while it's all apart, even belts and hoses.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is online now
post #5 of 13 Old 09-28-2008, 12:48 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
So I spent a good chunk of today pulling the TC cover and your hypothesis proved to be correct. There was absolutely no drivers-side guide to be found, and the timing chain had worn a pair of 1/8" deep tracks into the TC cover.
Since this truck is kind of a beater, I'm looking to do the repair on the cheap. (In all honesty, I was going to donate it to charity before I got the bug to use it as a learning tool.) Anyway, got a TC chain and cover kit on eBay that even comes with the water and oil pumps: $95 shipped. Then I bought a couple more gaskets as well as a steel guide so that I never have to do this again. Overall, $130 in parts and $50 in tools and hopefully she'll be running again. Based on these findings, I have no intention of pulling the head.
Overall, the most "fun" part of the teardown was breaking the crankshaft pulley bolt loose. A standard 1/2" drive socket wouldn't cut it; it took a trip to Kragen's for a breaker bar, and later a trip to Lowe's for 5' long iron pipe and and some PB Blaster. Soaked it with the PB for 5 minutes, and between it and the extra leverage it came of relatively easily.
Pictures of the "tracks" in the TC cover:
Picture of the TC cover behind the water pump (There was a nice crack. The picture makes it look worse than it is, but there's no doubt this is where the leak was.):
Nybbles is offline
post #6 of 13 Old 09-28-2008, 01:10 AM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
looks pretty good for your work in getting it apart. hope you get that thing running once more.
btw are there any better pics of the tracks? i wanna see them!
94 RN93 | *dead* | W58 | 2WD8"V6 | FX-R3.0 5000K 35W| 18x10.5 295/30/18
95 JZA80 | V160 | HKS Intake, Hipermax IV GT, & 4" Ti | RMS SS 3" DP | Bride Stradia | Nardi
89-95 Hilux Massive Truck Info
IronNam is offline
post #7 of 13 Old 09-28-2008, 03:17 AM
Quoted: 0 Post(s)
So now are you going to keep it, sell it or still donate it to charity?
pickuptruckguy is offline
post #8 of 13 Old 09-28-2008, 06:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
If I get her running, my plan is to keep her. She's a bit of a beater, but she was my first. She doesn't have A/C, but the heater works awesome so I'll use her to save some miles on my '09 Tacoma, especially during the cooler months.
You asked, I delivered .... more pics below.
On the 3rd picture, I've noted a couple more area's of damage on the TC cover. I can only assume that as the chain was rounding the crank gear, it caused that damage as well. The red box indicates an area where a good chunk of metal was very obviously worn down. It's hard to see in the pic, but the green box shows an area with the same kind of tracks as the side of the cover has.
Additionally, there is evidence that the chain was making contact with the head starting at the point the distributor bolts in at. They don't seem that bad to me, but I'm definitely keeping it in the back of my mind as I put this thing back together.
Also, in the 4th pic, you can see the tensioner in action. I have no basis for comparison, but it certainly seems that it's taking up a lot of slack. Additionally, as the chain is rotated in place, the slack seems to transfer back and forth between the driver and the passenger side of the truck, which seemed kind of odd to me. Does that sound normal?
Nybbles is offline
post #9 of 13 Old 09-28-2008, 06:47 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
dude thanx for the pics anyway. this will make looking down the timing chain cover more imaginative for me.
IronNam is offline
post #10 of 13 Old 09-29-2008, 12:54 AM
Quoted: 0 Post(s)
you just brought me back to my high school days.
post #11 of 13 Old 09-29-2008, 08:59 PM
Quoted: 0 Post(s)
How long has the engine been sitting with water in the crankcase?
In most cases where water has been circulating throughout the engine, it will cause the internals to rust (especailly the bearings) if the problem isn't tackled quickly. If it has been sitting for more than a month, it becomes a gamble if the engine will run without problems in the near future. Just an FYI.
qsd-dan is offline
post #12 of 13 Old 07-25-2011, 07:56 PM
Quoted: 0 Post(s)
How did this turn out? Did it run okay after replacing the cover, timing chain and everything else you thought you were going to fix?
netsomnia is offline
post #13 of 13 Old 07-28-2011, 12:31 AM
Quoted: 0 Post(s)
I made the mistake of putting my brandnew 22re together with a timing cover like that and after about the second day my brandnew engine was full of water and I damn near pulled the head luckily I pressurized the coolant system adn could see the water spraying from inside the cover. That was a lesson well learned.
Moto83 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
