Won't go into 4 wheel drive - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 19 Old 01-22-2009, 08:37 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I wonder if anyone has some insight regarding the engagement of 4wd system or lack there of. When I move the lever to 4wd hi it doesn't engage, all I get is the sound of electrical contacts coming from somewhere behind the dash. Any ideas?
stabulus is offline
post #2 of 19 Old 01-22-2009, 10:35 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 247 Post(s)
What year?
What engine?
Auto or manual transmission?
ADD?
Auto or manual hubs?
What about 4LOW?
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 19 Old 01-22-2009, 12:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Sorry for not including info in initial post. 1992,v6,manuel, I don't know what ADD is,auto hubs and it won't go into 4low either.
stabulus is offline
post #4 of 19 Old 01-22-2009, 03:44 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 247 Post(s)
ADD = Automatic Differential Disconnect, a system they had in the early 90's.
If you have auto hubs you don't have ADD, unless a previous owner put them on. With auto hubs you have to drive a bit for them to engage. If they haven't been maintained over the years, they tend to stop working.
Look here http://www.off-road.com/trucks4x4/ar....jsp?id=399612 to see if maybe you have ADD and auto hubs.
When you put it in 4WD (HI or LO) does the front drive shaft turn?
Does the 4WD dash indicator light up?
When you put in LO range, does it actually go into low? You should be able to feel the difference, even if 4WD (the front axle) isn't working.
89 4Runner - stock
fourwd1 is offline
post #5 of 19 Old 01-22-2009, 04:25 PM
Procrastinating on TN
knj27's Avatar
Quoted: 1 Post(s)
so are you saying you can't physically get the lever to pop into any of the 4wd positions? or the lever is fine and it just doesn't engage down below? Try putting it in reverse and rolling back just a bit while you try to shift the 4wd, that seems to work for a lot of sticky t-cases.
'93 Pickup 4x4 22R-E
knj27 is offline
post #6 of 19 Old 01-24-2009, 11:45 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The front driveshaft does turn, the 4wd dash light doesn't come on, it does go into low but 2 wheel drive. I've owned the truck since new so I don't think it has ADD. Oddly enough I can't move the 4wd shift lever when moving, I can only move lever into the 4wd position when stopped. I've tried the usual steps to engage but it won't go in.
stabulus is offline
post #7 of 19 Old 07-09-2009, 08:35 AM
Alex
Quoted: 0 Post(s)
Did you ever resolve this problem?? I Have a 94 22re pickup wit the same problem. Im not seeing the light when i shift into 4 high or low. The low gears work fine though in low.
ADJSmyth is offline
post #8 of 19 Old 07-10-2009, 09:35 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
No I haven't. It turns out it is equipped with ADD. I've looked at it several times, but haven't determined what has failed. If anyone has any suggestions I'd be glad to hear about them. Thanks
stabulus is offline
post #9 of 19 Old 07-10-2009, 03:46 PM
rod.s's Avatar
Quoted: 0 Post(s)
See my post concerning my ADD PROBLEM that I had with my truck, a 1994 toyota 4x4. My ADD was engaged all the time, so I purchased a set of manual freewheeling hubs and I just finished installing them and everything now works fine. Here is the link on how to disable the ADD system. You will have to do this as it seems your ADD is not engaging the front axle. If you jumper the two wires together on your ADD actuator on the front axle, the four wheel drive light will come on and off with your transfer case selector.http://www.4x4wire.com/toyota/tech/add/
rod.s is offline
post #10 of 19 Old 07-13-2009, 02:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks to rod.s and ADJSmyth for getting me thinking about this problem again. I sort of put it on the back burner what with summer and all. Anyway I found the problem, vacuum tank had a rust hole in it. I repaired the tank and put it back in service and ba-da-bing I got 4wheel drive back.
stabulus is offline
post #11 of 19 Old 09-29-2009, 08:51 PM
Quoted: 0 Post(s)
rod.s, when you say engaged all of the time do you mean the wheels were locked to the drivetrain or disconnected from?
I have this same issue and have been tracing vacuum lines and checking voltages and everything seems to be in order. I am puzzled. There was a hole in one line that had been taped by the prev. owner. Once that was repaired there was still no 4wd light like I was hoping for. Anyways, I am thinking that locking the ADD into 4wd might be my easiest option since I will be in there for the cv axles anyways. Winter here is 4wheel from oct-apr that should give me plenty of time to hunt down some manual hubs.
ETA: Are there any sources for manual hubs? It might be difficult for me to get a pair of aisins from a junked pickup.
AAhab is offline
post #12 of 19 Old 09-30-2009, 12:13 AM
Supafly
Jayota's Avatar
Quoted: 0 Post(s)
True auto hubs were never available after 88 (or 87).
ADD hubs are simply flanges that keep the cv axles constantly engauged to the wheel.
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline
post #13 of 19 Old 09-30-2009, 03:53 AM
rod.s's Avatar
Quoted: 0 Post(s)
What I found with my truck was the ADD actuator on the front axle was engaged in the on position all the time regardless of vacuum being there or not. I found it easier and most benefical to just bolt on a set of manual hubs(takes about a couple of hours) to correct this problem. If your actuator is not engaging at all you can just follow the instructions in the article posted above to keep it engaged at all times and locate a set of manual hubs for it, I found mine in an auto scrap yard,. You can also try ebay, not sure of what year trucks that will work with each other.
rod.s is offline
post #14 of 19 Old 10-01-2009, 04:10 PM
Quoted: 0 Post(s)
Yeah my actuator seems to be stuck in the off position after troubleshooting and repairs and getting vacuum all set at the actuator, it still fails to actuate. I read the article and it sounds pretty straight forward so I think I will give it a try. Sourcing a set of manual hubs will be the difficult part for me. As far I know any IFS hubs will work with any IFS system. The difference comes with the splines on IFS vs. Solid axles. Someone please correct me if I am wrong. Thanks for the help. Does anyone know of a source for aftermarket hubs if the search is devoid of fruit.
AAhab is offline
post #15 of 19 Old 10-01-2009, 05:48 PM
rod.s's Avatar
Quoted: 0 Post(s)
rod.s is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
