93 pickup, changed belt and now it won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Wheel & Tire Center
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 03-15-2009, 02:28 PM   #1 (permalink)
View kerbe6's Photo Gallery
I just changed the fan belt on my 93 pickup and now it won't start. The engine will turn over just fine but it acts as if it is completely out of gas. I know for sure that the plugs are firing. I've tried taking the belt off and it still won't start...so I obviously messed something up somehow.
What do you think?
kerbe6 is offline   Reply With Quote Quick reply to this message
Old 03-15-2009, 02:32 PM   #2 (permalink)
OLD SCHOOL
xsvtoyz's Avatar
View xsvtoyz's Photo Gallery
the fan belt was the object for you being under the hood but is not your no start issue. if it cranks then its either fuel or fire and you probably knocked a connection loose. did you disconnect the battery? check the fuses and fusible links. pull a plug and set it on the valve cover while attacked to the wire a look for spark. oops you said you have spark. did you make sure you didnt knock the maf wires loose down by the air filter? check for loose vacuum hoses. and yes still check the fuses and links
THE BLACK PEARL
recent mods: one eyed jack-in-the-box ball
xsvtoyz is offline   Reply With Quote Quick reply to this message
Old 03-15-2009, 02:34 PM   #3 (permalink)
I removed the distributor so that I had some room to work, but it's all put back together. I did not disconnect the battery. Like I said, the engine turns over, and the plugs are firing. I've searched high and low for any wires I may have left disconnected and can't find any. There are only a few fuses in this thing and they all are just fine.
Old 03-15-2009, 02:38 PM   #4 (permalink)
OLD SCHOOL
xsvtoyz's Avatar
well its almost definitely a timing issue set the crank at tdc and aim the rotor at #1
THE BLACK PEARL
Old 03-15-2009, 02:46 PM   #5 (permalink)
pardon my ignorance, but how would I do those things? I can swap parts just fine but I don't know much more about cars than that.
Old 03-15-2009, 03:11 PM   #6 (permalink)
OLD SCHOOL
xsvtoyz's Avatar
OK
the big pulley at the bottom is the crank pulley look for a small line near the motor and then look for marks on the motor itself. the line should line up with the 0 mark on the motor this should be top dead center or TDC if not then turn it till it does and yes exact is best. find plug #1 and remove the dist cap and make sure it points to #1. the cylinders are numbered look at the valve covers and they should have 1 3 5 and 2 4 6 on them and the 1 is closest to the radiator. I believe #1 is on the drivers side. follow the plug wire to the cap and mark it with something. pen/ soap /nail polish whatever doesnt matter just so you know which it is.
if its a 4 banger then it just got tons easier same basic approach but #1 is the first plug.
THE BLACK PEARL
Old 03-15-2009, 03:14 PM   #7 (permalink)
View War10ck's Photo Gallery
You might have kicked the oil pressure sensor wire off by accident.
War10ck is offline   Reply With Quote Quick reply to this message
Old 03-15-2009, 03:33 PM   #8 (permalink)
Well, little did I know, the distributor needs to be put on in just the right position for the timing to be right. I adjusted it and everything's running great. Thanks!
Old 03-15-2009, 06:05 PM   #9 (permalink)
View blue934x4's Photo Gallery
No offense, but it seems to me that the level of ignorance in anything automotive in this forum is increasing exponentially....if you have no clue as what you are doing... leave it alone, or ask BEFORE you try to "fix" things. Not knowing that you have to have the distributor in the proper position in order for the engine to run is really, really bad. Find someone who knows what they are doing and ask BEFORE you start "fixing" things.
blue934x4 is offline   Reply With Quote Quick reply to this message
Old 03-17-2009, 11:08 AM   #10 (permalink)
View moldycheese's Photo Gallery
but where is the fun in that? everyone has done something like that in there life. as long as you learn from your mistakes, then there is no harm done
350 SBC, 3" body lift, custom bumper, full width dana 44 and 12 bolt chevy,high steer, 36x14.5x15's.
moldycheese is offline   Reply With Quote Quick reply to this message
Old 03-17-2009, 12:43 PM   #11 (permalink)
"but where is the fun in that? everyone has done something like that in there life. as long as you learn from your mistakes, then there is no harm done"
I guess you never broke something really expensive or got hurt because you dove in before knowing what you were doing?
My point was and is, that if just ask first, you can save yourself, or others or your vehicle a lot of time and damage, and money or both. What happens if you "fix" something that comes apart while you are driving and you hit someone? Good luck explaining that you were "just learning from your mistakes" in court.
Old 03-17-2009, 01:35 PM   #12 (permalink)
OLD SCHOOL
xsvtoyz's Avatar
wow so much for leaning on this site
THE BLACK PEARL
Old 03-17-2009, 02:48 PM   #13 (permalink)
View marty_rk's Photo Gallery
Ya no kidding, if I never dove into anything, I wouldn't be where I am at now. Either way, the act of attempting anything is awesome! Props to kerbe for doing something yourself, can't be a body builder on the first day!
And while we are at it, whats the point of having forums when you dig up something old like from 2005 and someone comments on the fact that its old and then yells at someone for making a new thread about something in the archives? pick your wars people!
marty_rk is offline   Reply With Quote Quick reply to this message
Old 03-17-2009, 03:42 PM   #14 (permalink)
Well, now that I've made that mistake and learned a pretty good deal about how engine timing works, I still can't seem to get this thing running correctly. I've set my crank pulley at TDC and installed the distributor with the rotor at 11:00 (plug 1) and it won't start at all. However, if I turn the rotor 180 degrees it will start fine.
It doesn't run great though and misfires once it's warmed up and under load. the warmer it gets the more it misfires. When it's cold it runs great. Also, even when warm, I can gradually rev it up really high in neutral (no load) without any misfires. But then if I suddenly jam down on the gas pedal it will sputter.. The plug wires are definitely going to the correct plugs (1 2 3 4 from front to back on a 22re, right?).
Old 03-17-2009, 03:59 PM   #15 (permalink)
Ok scratch that. I can indeed start it at TDC with rotor at 11:00, I think I just had it a tooth off before. However, it's still misfiring under load when warm.
As far as I can tell I have the distributor adjusted about as well as I can. I can pull it out and rotate the rotor clockwise one tooth and put it back in and it will run best when the dist body is adjusted all the way up, or I can pull it out and rotate the rotor counterclockwise one tooth and have it run best when the dist body is adjusted all the way down. Unfortunately there doesn't seem to be any middle ground, where it runs best when the dist body is centered along the adjustment track.
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
