Doh! Rust on the engine block - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 8 Old 07-05-2009, 12:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I didn't think to spray down the inside of my hood this winter. (I'm new to salty winter roads), and I've got some rust spots on my engine block. WTF! I sprayed down my frame and wheel wells pretty good, but didn't think to wash the engine compartment.
Any tips to get that stuff off? I've read vinegar + steel wool or sandblasting (not an option at this point).
Is this really bad?
1993, 22re, 2wd, (w55)
152k mostly bone stock
Mods: Roof rack and basses in the back.
sevitzky is offline
post #2 of 8 Old 07-05-2009, 12:21 PM
Resident asshole
Flashmn's Avatar
Quoted: 2 Post(s)
Who cares its cast iron anyways, takes forever for it to be a problem.
Flashmn is offline
post #3 of 8 Old 07-05-2009, 08:13 PM
denniswoo's Avatar
Quoted: 0 Post(s)
you can use a product called osfo just brush it on and it will turn the rust back to usable metal and can be applied without a lot of sanding just knock the surface rust off.
denniswoo is offline
post #4 of 8 Old 07-06-2009, 11:52 AM
Resident asshole
Flashmn's Avatar
Quoted: 2 Post(s)
Once more, dont bother. If you want it to look good just paint it with engine enamel or por-15. All other work is just a waste of time.
Flashmn is offline
post #5 of 8 Old 07-06-2009, 08:07 PM
Senior TN Member
sb5walker's Avatar
Quoted: 0 Post(s)
http://www.toyotanation.com/forum/sh...25#post2764125
http://www.toyotanation.com/forum/sh...11#post2799311
If you want to do something about it, which is optional, as Flashmn points out.
89 4x4 X-Cab V6
WARNING: I'm not a professional tech - use any advice at your own risk. Working on vehicles is risky: you can kill or maim yourself or damage your truck if you don't know what you are doing. It's your responsibility to get qualified help if you lack auto repair training/experience.
sb5walker is offline
post #6 of 8 Old 07-07-2009, 11:54 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
That's a great post, SB5. Thanks for the link - I didn't see it in my search!
salt frickin sucks.
sevitzky is offline
post #7 of 8 Old 07-07-2009, 12:52 PM
Languishing in Virginia
TNRabbit's Avatar
Quoted: 0 Post(s)
Damn sb, that's one of the best posts I've ever seen on salt-related rust! I'm reposting here for posterity:
I've been wanting to write this up for a while, may as well be now. I learned about rust when I owned a 1964 Triumph TR4. For as long as I owned the car, I was engaged in an epic life-or-death battle with rust. I learned a lot - mostly what doesn't work - as I experienced fun things like having a rear fender fall off while rounding a curve, and, even more fun, having the steering gearbox break free of the rotting frame, jamming the steering just as I entered a curve. Both I and the owner of the brand-new split rail fence I destroyed found that episode quite amusing. Anyway, maybe this will help someone protect their truck:
There are two fairly effective ways to treat surface rust. I say fairly effective because nothing will work 100% or last forever. But you can knock it back pretty well.
The first approach is to use a "rust dissolver". That's a phosphoric acid etching solution, sometimes with added ingredients. Naval Jelly and Ospho are probably the two most popular. You absolutely must cover the treated area with an impervious oxygen and moisture barrier, otherwise the rust will start up again quite soon, sometimes within hours.
The second is to use a "rust converter" which chemically reacts with iron oxide to produce a compound that inhibits further rust. By itself, a rust converter will last much longer than a rust dissolver by itself, but ultimately a converter also needs an impervious topcoat for the longest lasting effect. Originally, rust converters were based on phosphoric acid, since it reacts with iron to produce iron phosphate, which provides the steel some protection from further rust. The best converters now use tannic acid, which reacts to produce iron tannate - a much more durable rust preventative than iron phosphate.
Most people who have treated rust with dissolvers or converters have found that they don't work for long on vehicles. The reason is salt. The salt ions actually chemically and electrically alter the steel to cause it to generate low voltage electricity that essentially does electro-plating in reverse: instead of depositing metal, the salt causes the metal to be electrically eroded. If steel has been in contact with road salt for an extended period, it is practically impossible to remove the chlorides from the steel, so even if you treat it with rust converter, the steel will still electrochemically corrode.
I actually did find a product that worked amazingly well on my old TR4 - for the surface rust. The problem was that by the time I found the product, most of the body and frame of my poor TR4 was shot through with rust, and when that happens, nuttin helps.
The product that worked quite well is "Fertan". It was developed for the British Navy, and it is used widely in the marine industry around the world. The reason Fertan works well is that it contains zinc. Zinc is electrically a more active "anode" than steel, and when in contact with steel it will sacrifice itself and protect the steel. Most ocean-going vessels have zinc clamped to the propeller shaft to protect the shaft and propeller from corrosion.
There's some info about Fertan here:
Fertan is great for the frame/suspension, especially if it's top-coated with one of the chassis paints listed in the post linked above.
BUT. The problem with Fertan is that it is somewhat "thick". It needs to be thick to provide a reservoir of zinc. For that reason, I'm not sure whether it would work for the inside of the wheel. I would worry that the surface would not be smooth enough to provide an air-tight seal for the tire.
So in your case, the rust dissolver/impervious topcoat approach might work better. Fortunately, there is a great dissolver that also contains zinc - and it probably would work well for those wheels. It's called "RustBlast" and it's made by KBS, a maker of coatings similar to (but I think better than) POR-15's product line. RustBlast is mainly phosphoric acid - it does dissolve rust like naval jelly or Ospho, but it also contains zinc phosphate that counteracts the chlorides that have infected the steel. It should be top-coated with KBS's "RustSeal" product or with POR-15. That provides a smooth, glossy, impervious finish that is very tough and also should provide a nice airtight seal for your tires.
Surface prep is everything, so you may want to sand the rusty areas smooth, clean and degrease the area with something like KBS's AquaKlean, then treat with RustBlast, and finish up with RustSeal. That's the best thing I can think of for those wheels.
http://www.kbs-coatings.com/Prep-Products_c_1-1-0.html
http://www.kbs-coatings.com/Rust-Sealer_c_2.html
http://www.kbs-coatings.com/KBS-Syst...-Kit_p_23.html
Oh yeah. I lost that life-or-death struggle with rust on the old Truimph. I learned that once rust has gone deep, nothing can stop the metal from returning to Mother Earth. I gave what was left of the car to another TR4 owner to use as a parts car. Too bad - that car had more "soul" than any vehicle I've ever driven. __________________
TNRabbit
STOCK '94 DLX XtraCab 4x4, 5 spd, 3VZE, 270,000 mi.
TNRabbit is offline
post #8 of 8 Old 07-08-2009, 01:20 PM
Resident asshole
Flashmn's Avatar
Quoted: 2 Post(s)
Actually rusting is just the result of metal "burning", like ashes are from wood. Moisture from the air that gets in contact with the frame is what causes it, salt is just a catalyst for the reaction. Main problem with toyota frames is the way they are built, they are 2 U-bars welded together on the outside, when the inside of the two is not protected by anything. Therefor it starts in the seam of the two, but the weld is much thicker than the actual metal so it spreads and the metal part corrodes away first.
Theres really no cure, except to patch it up when it starts to rot, only new frames can be protected with rust proofing compounds. The wax based is sprayed in the frame rails.
Another problemem with toyota frame rails is that the drain holes are very small and get clogged easily after which no moistue will drain from the rail. I had 1 inch of mud inside my frame.
Zinc only works as a protectant to the underlying steel, sacrificial zinc anodes work on boats, because they're in the salt water and the electrical pair from steel and zinc causes the less pure of them to sacrifice itself in favor of the more pure one. In this case steel survives zinc dosent. Like I said, it applies to boats, doesnt work on cars.
Flashmn is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
