hydraulic clutch leak 1988 hilux 4x4 - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 2 Old 10-10-2009, 02:24 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i have a1988 toyota 4cyl. 4x4 , 5speed . i have a leak on the clutch line appears to be at the tranny and it looks like a cylinder that hooks up to the tranny shifter any idea what it is called . don,t know much about toyotas just learning . thanks
ljds is offline
post #2 of 2 Old 10-10-2009, 03:42 PM
Senior TN Member
sb5walker's Avatar
Quoted: 0 Post(s)
It's called the clutch slave cylinder. If you want one of the same quality (that lasted 20 years, lol), that would be an Aisin. They are $34 at autohausaz.com A decent cheaper alternative is the Beck/Arnley - $18 from rockauto.com. Or you could get any old cylinder from a local parts store, but it won't be cheaper than the B/A and probably won't be as good. Another option, which I think would NOT be a good option, is a rebuild kit. That's only $10 from rockauto for the B/A kit (the best) but it won't do you any good if the cylinder is worn or corroded, and at 21 years, yours is probably both. So I wouldn't bother trying, and anyway, only 8 bucks cheaper than the complete cylinder.
Get a good DOT 4 brake fluid to completely flush the master & slave cyls. I like Valvoline SynPower which NAPA sells.
You may want to consider replacing the length of flexible rubber hydraulic line, since it's probably getting pretty tired, too.
And if you want to make a clean sweep, maybe the clutch master cyl also. Depends on how much preventative work you want to do, and how much $$ to spend. Check the stickied threads for hints on finding a factory service manual, which you absolutely should consult before doing the work.
89 4x4 X-Cab V6
WARNING: I'm not a professional tech - use any advice at your own risk. Working on vehicles is risky: you can kill or maim yourself or damage your truck if you don't know what you are doing. It's your responsibility to get qualified help if you lack auto repair training/experience.
sb5walker is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
ź Back
