Cleaning the throttle body on 22R-E - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
 1Likes
  • 1 Post By sb5walker
post #1 of 8 Old 12-30-2009, 01:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Is there a detailed thread with pictures on this process? I'm a pretty novice mechanic and I'm thinking about doing it myself. Thanks!
Doc Holliday187 is offline
post #2 of 8 Old 12-30-2009, 03:33 PM
Quoted: 0 Post(s)
i need help too
i notice that my throttle is sticking a little too. anyone with some advice?
vernon is offline
post #3 of 8 Old 12-30-2009, 04:23 PM
Puff Puff Pass
Breethroz's Avatar
Quoted: 0 Post(s)
I have done this but I have never seen a write up on it. I am not trying to insult you guys but all you do is remove the throttle body, get some throttle body cleaner to soak it in, get a used toothbrush and clean it. Then just reinstall it. Its pretty straight forward.
1992 22re 4wd extended cab ZERO rust.
2000 Lexus LX470
www.kushvana.com
Breethroz is offline
post #4 of 8 Old 12-30-2009, 05:41 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Any tricky stuff about removing and re-installing the throttle body itself? Any general tips?
post #5 of 8 Old 12-30-2009, 09:07 PM
Quoted: 0 Post(s)
I know it's been posted on here before, but make sure you do not submerge your TPS in the solvent. Bad things will happen in the not to distant future.
palmer_df0130 is offline
post #6 of 8 Old 12-31-2009, 01:58 AM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
^ true.
very simple, remember to make sure all the vacuum lines go in the correct places. spray some TB cleaner in the intake manifold also to freshen up a little bit.
spray some PB blaster along the Throttle cables also.
when you put it all back together, make sure to connect the intake tube tightly so its sealed and no leaks get by.
when you start up, it'll be a lil tough, just put your foot down on the gas
and you better have it in neutral or Park! be safe!
94 RN93 | *dead* | W58 | 2WD8"V6 | FX-R3.0 5000K 35W| 18x10.5 295/30/18
95 JZA80 | V160 | HKS Intake, Hipermax IV GT, & 4" Ti | RMS SS 3" DP | Bride Stradia | Nardi
89-95 Hilux Massive Truck Info
IronNam is offline
post #7 of 8 Old 12-31-2009, 10:26 AM
Senior TN Member
sb5walker's Avatar
Quoted: 0 Post(s)
  1. Do a seafoam treatment before cleaning the throttle body to clean the intake. Good time to clean the EGR passages too. If you are changing plugs and/or O2 sensor, do it after running the Seafoam treatment. See this thread: http://www.toyotanation.com/forum/sh...70#post2946870
  2. Take the throttle body off to clean it.
  3. Only use a cleaner made for throttle bodies. And a toothbrush. And clean t-shirt rags. Be sure to get both sides of the throttle plate/butterfly valve.
  4. If you soak your throttle position sensor (TPS) in any kind of solvent you'll be in the market for a new one. Probably would ruin your dashpot filter too. So don't soak it.
  5. Soaking could also destroy the rubber seals of the AAV/IAC - the cold idle-up valve. Okay to give a few shots of cleaner in the cold idle bypass passage (lower hole in front of butterfly valve), but invert it after to let the solvent run out. Hit the hot idle bypass (upper hole) with several good shots of cleaner too.
  6. After it's completely dry, put a drop of light oil like 3-in-One at each end of the throttle plate shaft and work it in.
  7. Check that the IDL and E2 contacts of the TPS have continuity when throttle is closed and do not have continuity when throttle is open - see the ENGINE - MFI SYSTEM - THROTTLE BODY section of the factory service manual (fsm). If they don't have continuity when closed, try adjusting position of the sensor per the fsm. If you can't get them to make contact, you need a new TPS. Check that resistance between VTA and E2 is in range with throttle in all positions, and verify that resistance smoothly increases and decreases as throttle is slowly opened and closed, with no spikes or dropouts (otherwise you need a new sensor).
  8. Use a new gasket when you remount the throttle body - the one from toyota is worlds better than the Fel-Pro you'll get from a parts store.
  9. Use the correct torque amount in the fsm - it's not much. Don't overtorque. If you don't have a torque wrench, you can try this technique when you first remove the throttle body: crack the mounting nuts in the remove direction to free them, then re-tighten to just a bit past their original position to get a feel for the right torque. The technique is iffy because the nuts may not have been torqued correctly when last mounted.
  10. Check operation of dashpot (& throttle opener if a 92-95 truck) - instructions in the fsm.
  11. Never adjust the throttle stop screw from its factory position.
  12. Make sure the air hose has no cracks or leaks.
  13. Reset idle to spec (22RE - 750 rpm; 3VZE - 800 rpm) by adjusting hot idle screw after engine has reached operating temperature. It's okay to make the speed a bit higher, up to 900 rpm max if the motor runs more smoothly at a different setting. (But when setting timing the speed needs to be at spec.)
JoeAllie likes this.
89 4x4 X-Cab V6
WARNING: I'm not a professional tech - use any advice at your own risk. Working on vehicles is risky: you can kill or maim yourself or damage your truck if you don't know what you are doing. It's your responsibility to get qualified help if you lack auto repair training/experience.
sb5walker is offline
post #8 of 8 Old 12-31-2009, 11:12 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks Einar.. As always your write up is very appreciated.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
