Manual transmission and rear end oil change - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
 1Likes
post #1 of 18 Old 03-12-2010, 03:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
1989 22r with 190,000 miles here. Recently had some work done at the local Toyota dealership. They recommended I change my manual transmission and rear end oil, which they were happy to do for $160.00. Is that necessary?
sasuga is offline
post #2 of 18 Old 03-12-2010, 03:33 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
you can do it yourself.
2wd manual?
94 RN93 | *dead* | W58 | 2WD8"V6 | FX-R3.0 5000K 35W| 18x10.5 295/30/18
95 JZA80 | V160 | HKS Intake, Hipermax IV GT, & 4" Ti | RMS SS 3" DP | Bride Stradia | Nardi
89-95 Hilux Massive Truck Info
IronNam is offline
post #3 of 18 Old 03-12-2010, 04:31 PM
Quoted: 1 Post(s)
If you are going to DIY I recommend an up grade to the synthetic of your choice.
V62WDLongbed is offline
post #4 of 18 Old 03-12-2010, 05:56 PM
Quoted: 0 Post(s)
Changing fliuds is always recomended after a certain amount of mileage. I change my trans and rear end fliuds in all my vehicles every 30k. Never hurts to change fluids.
Oil every 3k-3500
antifreeze once a year
brake fliud every two years
gear oil every 30k
trans if automatic every 30k
Jumbobret is offline
post #5 of 18 Old 03-12-2010, 09:31 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 296 Post(s)
When's the last time you had it done?
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #6 of 18 Old 03-12-2010, 10:48 PM
Senior TN Member
sb5walker's Avatar
Quoted: 0 Post(s)
GL-4 gear oil is strongly recommended for the manual tranny over the much more easily available GL-5. GL-5 is too slippery and doesn't work well with the synchros, causing hard shifting. Best GL-4s are Amsoil MTG and Red Line MT-90, both synthetic. Summitracing is a good source for Red Line products, if you can't find it locally. You must use GL-5 in the differential(s). You can use either oil in the transfer case (if you have one).
89 4x4 X-Cab V6
WARNING: I'm not a professional tech - use any advice at your own risk. Working on vehicles is risky: you can kill or maim yourself or damage your truck if you don't know what you are doing. It's your responsibility to get qualified help if you lack auto repair training/experience.
sb5walker is offline
post #7 of 18 Old 03-13-2010, 02:39 AM
turborich's Avatar
Quoted: 0 Post(s)
You can very easily do it yourself & save over $100 bucks. I would change the trans/rear end fluids if I were you. people often overlook these fluids.
1990 Toyota xtra cab V-6
turborich is offline
post #8 of 18 Old 03-13-2010, 04:59 PM
Supafly
Jayota's Avatar
Quoted: 0 Post(s)
don't forget the t-case
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline
post #9 of 18 Old 03-13-2010, 11:23 PM
Senior TN Member
verlaryder's Avatar
Quoted: 224 Post(s)
NAPA carry's Stalube 85W-90 GL-4 gear lubricant for your manual transmission and many brands of conventional 80W-90 GL-5 gear lubricant for your rear differential.
Toyota installed Conventional gear lubes in your truck at the factory because Toyota knows they can enable your tranny and rear end last 600,000+ miles. No one on this forum ever suffered from a worn out transmission or rear end because they failed to use synthetic oil so there is no legitimate reason to spend extra money on synthetics (except owners who live in subzero winter climates)
If your truck is two wheel drive you do not have a transfer case.
JoeAllie likes this.
verlaryder is offline
The Following User Says Thank You to verlaryder For This Useful Post:
JoeAllie (07-11-2014)
post #10 of 18 Old 03-14-2010, 12:59 AM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
UNLESS, it's an automatic, you may need to change fluid.
IronNam is offline
post #11 of 18 Old 07-09-2010, 09:52 AM
Senior TN Member
Quoted: 1 Post(s)
Question Fill allen plug
What is the size of the large allen plug you need to remove for the gear lube change in the tranny in a '92 22RE, 2WD 5-speed manual?
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row,155k. My family in-law have over 5 Toyota vehicles!
shortlid is offline
post #12 of 18 Old 07-09-2010, 12:47 PM
Senior TN Member
Quoted: 0 Post(s)
on the tranny i believe you just use a 3/8" drive ratchet just like the rear end. or is the rear end 1/2"?? i cant remember.
2009 Toyota Matrix: TRD springs, 4300k HIDs
1993 Toyota pickup SOLD with 196khttp://www.toyotanation.com/forum/sh...d.php?t=308080
http://s21.photobucket.com/albums/b252/adam68/
Ajones1165 is offline
post #13 of 18 Old 07-09-2010, 12:48 PM
Senior TN Member
Quoted: 0 Post(s)
No, the rear end isnt a ratchet head nevermind.
post #14 of 18 Old 07-12-2010, 03:51 PM
initiate's Avatar
Quoted: 0 Post(s)
My plug to change the gear oil was not allen. It was a normal 24mm head. I know because I had to go out to Sears at 9pm and find one. I have a '94 22RE, 2wd manual.
initiate is offline
The Following User Says Thank You to initiate For This Useful Post:
shortlid (07-12-2010)
post #15 of 18 Old 07-12-2010, 04:19 PM
Senior TN Member
Quoted: 1 Post(s)
OK so 24mm wrench or socket will do it cool!
shortlid is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
