Hi There are a bunch of little threads about ignition switch replacement but most are a little vague Im wondering if anyone can give me a good procedure for ignition switch and key cylinder replacement. this is a 92 x cab 4x4 4 cylinder 5 speed pickup
IT should be pretty straight forward, remove the surround. Unclip the wiring from the cylinder. Then snap the breakaway bolts that hold the cylinder in and remove it.
I have a 92, All I did was put the key in "ACC", and pushed the button on the bottom of the cylinder, and it popped right out. The new one slides in the same way.
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
586.9K members
Since 2001
