Bucking at Low Speed, poor acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 3 Old 07-15-2010, 03:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello, I have a 1993 Toyota Pickup 4x4 MT 3.0 V6 extended cab. Sometimes when I start down the road when the engine is cold, it wants to buck for about 5 to 10 seconds. It will eventually smooth out. Also I've noticed that when the engine reaches 2500 RPMs it starts to pull really well. It's not a gradual thing, but almost feels like a flooded cylinder kicking in. This only happens on occasion.
Here is what I've done so far:
Replaced Vane Air Flow Meter
Cleaned Throttle body
Inspected and adjusted TPS
checked timing (within spec)
Replaced clutch, pressure plate, pilot bearing, and throw out bearing, and rear main seal
new plugs, wires, distributor and rotor button
replaced PCV valve
new coil
new battery
replaced intake plenum gasket and tested injectors with ohm meter
Replaced fuel filter
Seafoamed engine and fuel system
Tested fuel pressure at the cold star injector (40psi at idle)
Tested engine coolant temp sensor (within spec)
Tested 02 sensor (within spec although I did have a code 21 once but it's never came back on)
I've tried my best to figure this problem out but nothing seems to fix it. Any ideas are good ideas.
Thanks in advance.
Kevin
KevinCro is offline
post #2 of 3 Old 11-18-2013, 10:17 PM
Quoted: 0 Post(s)
I get this same behavior until my truck warms up to operating temp...
TL697 is offline
post #3 of 3 Old 11-19-2013, 06:45 AM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
Could be a leaking injector or CSI causing a flooded cylinder...
Not sure. I'm not as familiar with the foibles of the 3wheezy
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
