1993 toyota pickup 4 wheel drive problem - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 4 Old 08-09-2010, 01:48 PM Thread Starter
HessyX2's Avatar
Quoted: 0 Post(s)
(Thread Starter)
i have a 1993 22re toyota pickup extended cab i lifted and when doing so i dont remeber why but i had to swap front differentials and i dont remember what differential i used the one outta my 1989 22re regular pickup or the one outta the 1991 v6 extended cab i parted out. anyway my problem is that i just was in my backyard and it put it in 4-low and in 1st just let the clutch out and had it creep on idle and when it moves about 2ft the truck will stop moving and just lock up tight untill i put it in reverse and back up the 2ft and same goes in revers if i move 2ft it will stop moving, i noticed if the hubs are locked and im not in 4 wheel it moves but the second i put it in 4 wheel i can move about 2ft and it will lock up. please help does that mean the front diff i put in has a different ratio?
HessyX2 is offline
post #2 of 4 Old 08-09-2010, 02:20 PM
TOYsRus
Quoted: 0 Post(s)
It takes about 2ft for the hubs to lock and unlock on some trucks...
It sounds to me like your Front Diff is locked up and not moving.... that or the front part of the transfer case but that seems less likely.
Put it in the air in neutral lock the hubs and see if you can turn it by hand, then drop the front drive shaft and try again... this will tell you which item is binding up.
2011 Black DC Limited 5.7FFV 4x4
Like the others, let the modding begin!.
2001 WS6 Ram Air-450RWHP
2008 VRod- Night Rod Special-stock..
killer01Ws6 is offline
post #3 of 4 Old 08-09-2010, 02:39 PM
Quoted: 0 Post(s)
If the front diff is different gearing it could bind it up this way. be very careful!
1989 Toyota Extended cab 4x4
22RE 5spd
BrianJE is offline
post #4 of 4 Old 08-09-2010, 03:25 PM Thread Starter
HessyX2's Avatar
Quoted: 0 Post(s)
(Thread Starter)
if i have the truck in the air in and the 4wd shifter set to netural and spin a tire the front drivshaft spins. if i have it in 4-low and spin a tire the front driveshaft does not move only the other tire
HessyX2 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
