radio removal - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 6 Old 08-17-2010, 10:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
radio removal
Can anyone tell me what is involved in removing the radio from a 1994 toyota extended cab pickup?
Also does anyone know where a bumper for this truck can be found?
toytran is offline
post #2 of 6 Old 08-18-2010, 04:27 PM
Supafly
Jayota's Avatar
Quoted: 0 Post(s)
First undo the battery, you don't want to short anything out!
Radio removal requires removal of both the lower drivers side dash panel and the passenger side glove box. Both quite easy to unbolt and set aside (1 bolt and a few phillips screws). Then you will need to pop off the ignition surround (pops off), the heater controls (using a very thin flat head, after you have removed the heater knobs, pry the face plate from the passenger side out. Don't be afraid, it likes to bend.
You will then be able to remove the phillips screws holding the radio surround into the dash, once that is removed removing the headunit is simply a few bolts away (easy to figure it out at that point).
What kind of bumper are you looking for?
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline
post #3 of 6 Old 08-20-2010, 03:58 PM
Quoted: 0 Post(s)
Try here:
http://www.installdr.com/InstallDocs/Toyota/Trucks.html
I found this on a search of this forum a while ago.
___________________
1990 Pickup SR5 2wd V6
2002 Camry LXE
tcanu is offline
post #4 of 6 Old 08-20-2010, 09:35 PM
Not a Pre-runner
Twisted Sid's Avatar
Quoted: 73 Post(s)
usually in the front or the rear of the truck
94 Pickup:22RE, 5spd, 2wd
Total Chaos Uniball Kit, Fox 8''Coilovers, Deavers, Fox 14'' 2.0s, E-locker Axle 33x10.5 BFGs
99 4Runner: V6 Daily Driver
Twisted Sid is offline
post #5 of 6 Old 08-02-2014, 01:17 AM
Quoted: 0 Post(s)
tcanu - cheers for that link - you're a legend
aladdinsane is offline
post #6 of 6 Old 08-04-2014, 02:41 PM
Top Teke's Avatar
Quoted: 0 Post(s)
I've got a chrome front bumper I'll sell you. PM me if you're interested.
94 22RE SAS, 37s, 4:88s, twin sticks, Detroit, FJ60, Bilstein, Chevy 63", double shackles, Dirty 30s, Flowmaster, Alpine
07 G35 6MT coupe
88 FXLR
Top Teke is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
