1993 toyota pickup speedometer stopped working - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 18 Old 10-17-2010, 05:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
the speedometer on my truck has been slowly dying..I used to be able to tap it and it would start to work..now it is not woring at all...do I have a cable or a sensor..any help would be great
Toyauto is offline
post #2 of 18 Old 10-17-2010, 05:14 PM
Newbbie
04 3RZFE's Avatar
Quoted: 0 Post(s)
Pretty sure you have a sensor, i think the culprit may be your speed sensor, but if i were you i would first pull out the instrument cluster and inspect the electrical connections in the back and if you can, drive CAREFULLY and wiggle the connections around to see if its your cluster. If nothing happens its your speed sensor, who knows it could be an easy fix!
04 3RZFE is offline
post #3 of 18 Old 10-17-2010, 06:50 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 272 Post(s)
93 was sorta the crossover point, you could have cable or electronic.
To find out for sure, get under your truck and look.
If its 4wd the sender is in the t-case, if 2wd its in the trans.
Once you locate it and determine what you have, check it for obvious problems (loose, broken wire, etc).
With the proper info, we can tell you where to go from there.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is online now
post #4 of 18 Old 10-17-2010, 07:12 PM
tron1.8's Avatar
Quoted: 0 Post(s)
My 93 is electrical and I also have been having issues. Seems to be an issue and a few people have posted on this site and toyotaminis- no answers yet. Not the sensor- I'm going for ground and will pull out my cluster once next weekend. Mine reads high and sometimes where I turn on a blinker it will go down to normal or sometimes go up and down. I will post what I find later.
1981 Corolla Sedan- Sold
1993 Pickup 22RE-82 Supra AFM/battery flip
2010 Corolla LE
tron1.8 is offline
post #5 of 18 Old 10-17-2010, 08:28 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks
I have a sensor...thanks for any help you can give
Toyauto is offline
post #6 of 18 Old 11-19-2010, 02:38 PM
sterfry's Avatar
Quoted: 0 Post(s)
I also have the same problem! I got a new vss but cant locate where to put it. I read its on the t-case but still confused. Some help would be much appreciated!
sterfry is offline
post #7 of 18 Old 11-19-2010, 02:53 PM
Lemon Jelly Donut
rivethed's Avatar
Quoted: 0 Post(s)
without , more info, hard to be certain, but try the passenger side of the t-case, near or in the extension housing (rear-part) held on with one bolt, and the connector is either straight out the side or angled upwards (the connector).
"These are my experiences, yours will vary!"
06 Taco AccessCab, 4.ohhhh, Prerunner Sr5
93 xtra cab "pig pen" (sold, /me pours the "red stuff" out in remembrance)
?? ISO the next project
rivethed is offline
post #8 of 18 Old 11-26-2011, 06:44 PM
bensyota's Avatar
Quoted: 0 Post(s)
did you solve this problem yet?
-93 dlx reg cab,115k V6,5spd,31" at ko's,front bj spacers,rear 2" skyjacker aal,aisin manual hubs conversion, -93 toyota ext cab,160k,v6, 5spd,32" km2,3in lift,magnaflow exhaust,arizona truckbabyhttp://www.toyotanation.com/forum/80...d-project.html
bensyota is offline
post #9 of 18 Old 12-23-2011, 03:08 AM
Quoted: 0 Post(s)
Anyone know where to find the best price an a electronic speed sensor for a 93 2wd? They seem to be pricey
helloitsme is offline
post #10 of 18 Old 12-23-2011, 08:31 AM
Quoted: 0 Post(s)
The speed sensors are pricey and from my research are usually not the culprit in this case. I had it diagnosed at the dealership and in my case it is the actual guage cluster itself. Tech said the cluster has to be replaced. I have been waiting for someone to discover the magical econo solution but nothing so far. Mine has been intermittent for the past couple years doesnt like wet weather at all. I just deal with it for now cause a new cluster is pricey.
There are a few threads in the forum of folks who replaced the speed sensor under assumption and were sorely disapointed when it did not resolve the issue.
I have not torn the dash apart to get a good look but I feel that the conclusion would most likely be the same which is to replace the entire cluster. Hope this gives you some reference at least.
I like to get parts at these sites:
http://www.toyotapartsales.com/partl...?siteid=214074
http://www.toyotapartszone.com/
REDTACO is offline
post #11 of 18 Old 12-25-2011, 09:07 PM
Quoted: 0 Post(s)
vehicle speed sensor
You might try this. Worked for me.
http://www.ebay.com/itm/91-92-93-94-...item3361af2779
deermike is offline
post #12 of 18 Old 04-15-2012, 07:30 PM
Quoted: 0 Post(s)
Speed Sensor did not fix
I have a 94 Toyota xcab 4X4. When the speedo went out, I replaced the speed sensor. That didn't fix the problem, so I replaced the instrument cluster with a used one. The speedo now works, but is off by 12 MPH. Any suggestions?
zooo is offline
post #13 of 18 Old 04-15-2012, 08:23 PM
Quoted: 0 Post(s)
Always 12 MPH?
Tire size?
Mine seems 10-15% off a little running 235s, it reads faster than what I'm really going. Cant remember if the truck originally takes 235s or 225s, though.
thctravel is offline
post #14 of 18 Old 04-15-2012, 09:17 PM
Quoted: 0 Post(s)
Yes, Always 12 MPH. I have to get up to 12 MPH before the needle will move off of the "0", so my 31X10.5 R15 tires should nort be a factor. Tried with 2 different speed sensors with the same result. Starting to wonder if the instrument cluster that I bought off ebay already had speedo issues. http://www.ebay.com/itm/180851724564...witem=&vxp=mtr
zooo is offline
The Following User Says Thank You to zooo For This Useful Post:
Owner_of_2_Camrys (08-16-2012)
post #15 of 18 Old 04-16-2012, 07:08 AM
Quoted: 0 Post(s)
Kinda touchy but worked for me. Leave the cover off the inst. cluster. Use GPS to determine speed and pull the speedo needle and reset according to GPS.
deermike is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
