Emergency Brake cable adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 7 Old 10-18-2010, 06:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
just put new rear shoes on 95 p/u 4x4..drum brakes on rear...found the adjustment bolt on passengers side at where the bed and cab meet..question is how does this bolt turn to tighten and take slack out of cable...cant seem to figure out how this bolt is supposed to turn..any help appreciated...thanx...
96vettelt4 is offline
post #2 of 7 Old 10-18-2010, 07:36 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 177 Post(s)
There should be 2 nuts. Loosen the top one (lock nut) then turn the inner one to tighten up the cable.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 7 Old 10-18-2010, 11:17 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i'll look at it again but it looks like one long bolt..maybe im missing where they connect...thanx....
post #4 of 7 Old 10-22-2010, 05:34 PM
Supafly
Jayota's Avatar
Quoted: 0 Post(s)
tighten the nut and it pulls the threaded rod thru farther.
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline
post #5 of 7 Old 10-24-2010, 01:12 PM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
make sure the brakes are adjusted in the drum first. they should be almost or just barely dragging when the brakes are not applied.
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
post #6 of 7 Old 10-24-2010, 05:21 PM
Supafly
Jayota's Avatar
Quoted: 0 Post(s)
Make sure the auto adjusters are working as well. They work like a hot damn when they work properly.
Jayota is offline
post #7 of 7 Old 10-24-2010, 06:39 PM
Senior TN Member
sb5walker's Avatar
Quoted: 0 Post(s)
Good advice to service the drum brakes before touching the e-brake cable. Also make sure that the L-shaped parking brake "bellcrank levers" are not frozen where they go through the backing plate. (They're the levers the parking brake cables attach to, and they like to freeze up in the brackets. I had to replace the lever, bracket and pin on my drivers side.)
Some drum brake servicing info:
brake drum removal issue
http://www.4x4wire.com/toyota/maintenance/rearbrakes/
http://www.toyotanation.com/forum/sh...81#post2934781
89 4x4 X-Cab V6
WARNING: I'm not a professional tech - use any advice at your own risk. Working on vehicles is risky: you can kill or maim yourself or damage your truck if you don't know what you are doing. It's your responsibility to get qualified help if you lack auto repair training/experience.
sb5walker is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
