22RE Fuel Filter replacement - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 17 Old 01-05-2011, 03:04 PM Thread Starter
Senior TN Member
Quoted: 1 Post(s)
(Thread Starter)
Question 22RE Fuel Filter replacement
Guys, the fuel filter on this '94 22RE powered pick-up look like a bear to replace!!! Any tip and tricks would help!
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row,155k. My family in-law have over 5 Toyota vehicles!
shortlid is offline
post #2 of 17 Old 01-05-2011, 03:11 PM
Puff Puff Pass
Breethroz's Avatar
Quoted: 0 Post(s)
I hate it for you my friend. I personally have not had to replace mine ever so I have no personal insight, but I have seen others on here that have and all of them complain that its a major PITA.
1992 22re 4wd extended cab ZERO rust.
2000 Lexus LX470
www.kushvana.com
Breethroz is offline
post #3 of 17 Old 01-05-2011, 03:24 PM
i am sherbasm
sherbasm's Avatar
Quoted: 0 Post(s)
i suggest using a manual such as haynes
sherbasm is offline
post #4 of 17 Old 01-05-2011, 03:56 PM
Quoted: 0 Post(s)
Seriously, it's not that hard. First, remove the pass front wheel. Have the frontend jacked up a bit so you can sit in the wheelwell. I couldnt get my damn wheel off, so I just went over the tire, but it would have been even easier with it off. Use a 17mm wrench to loosen both fuel lines. the use a 12mm shallow socket on a u-joint with a 12" extension to remove the top and bottom bolts. pull the filter toward you and remove the (loosened) fuel lines. Install the new filter onto the fuel lines hand tight. Bolt the filter back to the block tight(the top bolt is a little tricky to get aligned, but you have a good view of it through the wheelwell). Then tighten the fuel lines with your wrench. Start the truck and check for leaks. If there are any, loosening then retightening the fuel lines may work, otherwise take it back off, use new copper washers, and make sure the lines, threads, and mating surfaces are spotless, and reinstall. Tip:Use a drop light stuck in the engine compartment from above. I read about how people try the replacement from above, without being able to see the filter. That's ridiculous. Through the wheelwell works great. Jim
68grandprix is offline
The Following 2 Users Say Thank You to 68grandprix For This Useful Post:
shortlid (01-05-2011), williesmith2008 (12-27-2012)
post #5 of 17 Old 01-05-2011, 04:00 PM
Quoted: 0 Post(s)
Oh, also, the manual is f-ing useless for this job.
post #6 of 17 Old 01-05-2011, 04:49 PM
Newbbie
04 3RZFE's Avatar
Quoted: 0 Post(s)
Ya its not fun, but it can be done. BE PATIENT!!!! If you have a short fuse then let someone else do it. It will save you from in on your truck!!!
04 3RZFE is offline
post #7 of 17 Old 01-05-2011, 05:31 PM
Quoted: 0 Post(s)
I'm 6'1", I have big hands (hard to get in small spaces) and a messed up back. I was hitting my damn tire with a big log(I don't have a sledge) as hard as I could to try and get the wheel free. I was doing all this in 10degree weather. Even after all that bull, I was still able to replace the filter pretty easily (twice, since the replacement from Vatozone only came with two copper washers, instead of the four required, and I had a leak the first time). So it was a pain(in my back), but not because of the filter. Just because of bs like a seized wheel and incomplete replacement kit. Jim
post #8 of 17 Old 01-05-2011, 05:52 PM
hector113's Avatar
Quoted: 0 Post(s)
When I did my clutch I found buy taking off the starter is the beat way. You just need long extensions to get the bolts off. To put the bolts back in I used tape to hold the bolt in the socket. Its more work but its less of a pain todo if that makes sense.
hector113 is offline
post #9 of 17 Old 01-05-2011, 05:54 PM
Tech1984's Avatar
Quoted: 7 Post(s)
Just loosen the wheel lugs and drive it slowly in circles. Worked everytime for me.
The 4X4 has an access panel in the wheel well. The 4X2 does not. I just remove the fender apron seal and bend the inner fender up with large channel locks to allow arms to reach in there.
Don't worry, the metal bends right back into shape once the new filter is on.
Bin wrenchin' on the Yota's since '84
30th anniversary 2014
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline
post #10 of 17 Old 01-05-2011, 06:37 PM
HEAVY_GD's Avatar
Quoted: 0 Post(s)
Bodylift FTW!!
HEAVY_GD is offline
post #11 of 17 Old 01-06-2011, 12:23 PM
Quoted: 4 Post(s)
I took the tire and the starter out to get to the filter. It's a pain to get to, but take your time. A good set of extensions and wrenches help.
Best of luck.
sometoyotaguy is offline
post #12 of 17 Old 01-06-2011, 01:23 PM
Gettin' on it
Matdy's Avatar
Quoted: 0 Post(s)
I just did this on my brother's 4runner and second (or third??) taking the starter off. Not as bad as it's made out to be...15 min job, tops.
Matdy is offline
post #13 of 17 Old 01-06-2011, 04:33 PM
Quoted: 0 Post(s)
I took all but three lug nuts off, and loosened the three that were left on. I drove the truck off a jack(one foot drop), I drove around and took a couple turns, I ran up and down the curb in front of the house. Nothing worked to loosen the wheel. If I get a Saturday off I'm going down the street to the Ford dealership where my bro-in-law is the service manager to use their oxy-acetylene outfit to heat the wheel center then use a large dead-blow hammer to break it loose. For now I make sure to carry a can of truck fixaflat in addition to my spare. Jim
post #14 of 17 Old 01-07-2011, 02:49 PM
Quoted: 0 Post(s)
Originally Posted by HEAVY_GD View Post
Bodylift FTW!!
hahahahahahah
i dont mean to change the subject, but i had the exact same problem, 68grandprix (wheel wouldnt come off)
i drove on my too, used inclines and whatnot, beat 'er with a sledge. nothing. finally, made this sort home made reverse clamp deal. i stuck a long 4x4 piece of wood between the two tires, and then stuck the jack (that came with the truck; any ol car jack should work) between one end and the tire. i had to stick a 2x6 between the jack and tire so i didnt ruin my tire. i cranked up the jack and it worked like a charm.
mrprez is offline
post #15 of 17 Old 01-09-2011, 10:02 AM
JungleJim's Avatar
Quoted: 0 Post(s)
A friend of mine had the same problem with a rear wheel. We couldn't get it off. A muffler chain garage nearby, had a "free brake inspection" goin' on. We took it there and they fought with it for 20 min. They said the rear brakes need to be done. So my buddy says he'll have to wait for payday. We went back and did the brakes.
Tryin' to keep my spirits up, and my demons down.
JungleJim is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
