Dashpot - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 12 Old 02-06-2011, 10:15 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Dashpot
Found out that my dashpot on my '94 Yota is bad. It wasn't letting the truck idle down when warm. I tried to lube it with silicon spray as 4X4crawler suggested in a write up, but no dice. I looked for a replacement at advance auto, oreliy and napa with no luck. Is this a dealer only part?
________________________
1994 Toyota Pickup, STD, 2WD , 22RE , 5 Speed.
KC_YOTA is offline
post #2 of 12 Old 02-06-2011, 12:07 PM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
You can have mine. 91 22re. I have it disconnected anyway. $20 shipped.
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
The Following 2 Users Say Thank You to kamesama980 For This Useful Post:
HEAVY_GD (02-09-2011), shortlid (02-07-2011)
post #3 of 12 Old 02-07-2011, 09:57 AM
Senior TN Member
Quoted: 1 Post(s)
Nice kamesama980! Love to see when the board memebers can help each other out! How often do these go bad in 22RE's?
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row,155k. My family in-law have over 5 Toyota vehicles!
shortlid is offline
post #4 of 12 Old 02-09-2011, 09:17 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank you for the offer kamesama980, but now I am not thinking it is the dashpot causing the problem. The issue I am having is that the truck idles fine after start up, but once you start to drive it, it idle high. Its like the throttle is getting stuck open a little. I can push the throttle closed by hand and the idle will drop back to normal. I can also tap the gas peddle real quickly while stopped and it will drop the idle back down 90% of the time. I have changed the idle air control valve, adjusted the throttle plate stop, adjusted the TPS and have backed the adjustment screw for the dashpot all the way out. I have also triple checked the throttle cable and there is plenty of slack and don’t think it is the problem. Anyone have any ideas?
KC_YOTA is offline
post #5 of 12 Old 02-09-2011, 12:21 PM
Georgian Pickup Drifter
Mushroom_Toy's Avatar
Quoted: 0 Post(s)
Originally Posted by KC_YOTA View Post
Thank you for the offer kamesama980, but now I am not thinking it is the dashpot causing the problem. The issue I am having is that the truck idles fine after start up, but once you start to drive it, it idle high. Its like the throttle is getting stuck open a little. I can push the throttle closed by hand and the idle will drop back to normal. I can also tap the gas peddle real quickly while stopped and it will drop the idle back down 90% of the time. I have changed the idle air control valve, adjusted the throttle plate stop, adjusted the TPS and have backed the adjustment screw for the dashpot all the way out. I have also triple checked the throttle cable and there is plenty of slack and donĺt think it is the problem. Anyone have any ideas?
Its either idle speed when it gets warm, or on mine, I ended up putting a heavy gauge throttle return spring on, because for some reason no matter what I did the throttle plate started sticking, of course I run no dashpot either.
-:- NGK -:- American Racing -:- Denso -:- Mobil 1 -:- KYB -:- Belltech -:-
2nd Gen Camry Parts for sale or trade. Pm for Details.
Need 89-94 4x4 or 4runner parts.
Mushroom_Toy is offline
The Following User Says Thank You to Mushroom_Toy For This Useful Post:
KC_YOTA (02-09-2011)
post #6 of 12 Old 02-09-2011, 12:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I was thinking return spring might be the next thing to try. Where did you get the spring from?
KC_YOTA is offline
post #7 of 12 Old 02-09-2011, 01:06 PM
Languishing in Virginia
TNRabbit's Avatar
Quoted: 0 Post(s)
Also, check that no carbon build-up is blocking the throttle plate from closing all the way~
TNRabbit
STOCK '94 DLX XtraCab 4x4, 5 spd, 3VZE, 270,000 mi.
TNRabbit is offline
The Following User Says Thank You to TNRabbit For This Useful Post:
post #8 of 12 Old 02-09-2011, 03:09 PM
Senior TN Member
Quoted: 0 Post(s)
^^^^^^^^^^^^^ after reading through the problem, i would suggest this. Buy a can of brake clean or carb clean, get an old tooth brush, and pull the intake tube. clean all around in there. also pull the idle screw out, and clean the tip of it off, and spray/clean inside that hole.
Almost garenteed to fix the problem.
2009 Toyota Matrix: TRD springs, 4300k HIDs
1993 Toyota pickup SOLD with 196khttp://www.toyotanation.com/forum/sh...d.php?t=308080
http://s21.photobucket.com/albums/b252/adam68/
Ajones1165 is offline
The Following User Says Thank You to Ajones1165 For This Useful Post:
post #9 of 12 Old 02-09-2011, 03:31 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the tip. When I had the throttle body off to replace the idle air control valve, I cleaned the TB very thoroughly with TB cleaner and a tooth brush. So no carbon to speak of after the cleaning.
KC_YOTA is offline
post #10 of 12 Old 02-09-2011, 03:34 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Another good tip. I did not know that the idle screw came out and that you could clean the tip and hole. I will give that a try when I get home today and report back.
KC_YOTA is offline
post #11 of 12 Old 02-12-2011, 10:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok, so i pulled out the screw and cleaned it and the hole. No dice. Still doing it. Maybe the spring is not strong enough as suggested? Any ideas on where to get a replacement/upgrade?
KC_YOTA is offline
The Following User Says Thank You to KC_YOTA For This Useful Post:
shortlid (02-14-2011)
post #12 of 12 Old 02-16-2011, 10:31 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok, so I think I finally fixed the high idle issue. I lubed the pivot points and around the edge of the butterfly valve in the throttle body. Used a very light coat of 3 in 1 oil. I am not sure why this happened. Maybe the factory lube got washed out when I cleaned it. But I used TB cleaner from CRC, so not sure why that happened. O well, glad I got it resolved. On to the next issueů.
KC_YOTA is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
ź Back
