Steering and Shaking - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 7 Old 07-23-2011, 01:11 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hows it going guys. great forum, and love the wisdom you guys share
I have a 93 2wd 3.0 and this past couple weeks i've noticed some things.
While driving, if i let go of the steering wheel, it pulls to the right.
When driving, the steering wheel and the truck as a whole shake/vibrate. And its very pronounced from 40 to 60 mph.
I'm thinking ball joints or shocks. The suspensions due for an update anyway! Just got the truck about 6 months ago.
Thanks so much in advance!
1993 Toyota Pickup SR5 3.0 V6 - For Work
1987 Porsche 944 - For Play
enthuzed1 is offline
post #2 of 7 Old 07-23-2011, 09:42 AM
Quoted: 1 Post(s)
The shaking could be due to a bad rim or tire. Also, as you've suggested, you may need new shocks or suspension parts.
The pulling to the right could be caused by a tire or an alignment issue.
V62WDLongbed is offline
post #3 of 7 Old 07-23-2011, 04:44 PM
YOTA Master
Vicoor's Avatar
Quoted: 3 Post(s)
The first place to look is the tires.
Generally a vibration (shake) will be created by an irregularity in a tire or rim. Seldom will a steering or suspension component cause a vibration. They will make an existing vibration much worse though.
Pulling can be caused by alignment issues caused by bad suspension parts, brake problems,
Or,,,, Bad tires.
With both a vibration and a pull it is very likely to be a tire issue.
Hope this helps
Victor
Don't talk about it, Just do it!
Vicoor is offline
post #4 of 7 Old 07-23-2011, 09:13 PM
Quoted: 0 Post(s)
you might haive a flat spot on tire. if it is rotate the tire since the rear axle is solid it won't shake as much
Pitbull90 is offline
post #5 of 7 Old 07-26-2011, 05:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
So just checked the tire, they're fine. Looks like im gonna have to replace the ball joints though.
Also I've noticed that the passenger side is leaning lower than the drivers side. Looks like I gotta replace the shocks. But would that be the major cause of my steering/vibration issue?
post #6 of 7 Old 07-26-2011, 06:08 PM
Quoted: 1 Post(s)
Originally Posted by enthuzed1 View Post
...I've noticed that the passenger side is leaning lower than the drivers side. Looks like I gotta replace the shocks. But would that be the major cause of my steering/vibration issue?
More likely you need to adjust the torsion bar on one side to level out the front end.
Did you have the tires rebalanced or have them rotated front to back?
Have you had anyone drive along side of you to see if they can observe any problems?
post #7 of 7 Old 07-26-2011, 08:09 PM
Senior TN Member
sb5walker's Avatar
Quoted: 0 Post(s)
When my truck had a wicked shimmy at about 45-60 it turned out to be worn bushings in the idler arm. Those can be replaced, cheaply. Check the 'massive truck info' sticky for links on how-to threads.
89 4x4 X-Cab V6
WARNING: I'm not a professional tech - use any advice at your own risk. Working on vehicles is risky: you can kill or maim yourself or damage your truck if you don't know what you are doing. It's your responsibility to get qualified help if you lack auto repair training/experience.
sb5walker is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
