92 Toyota Truck 22RE will not start - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 5 Old 11-13-2011, 08:17 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello. I am new to the forum and have searched but cannot find the answer to my question. I have a 1992 Toyota truck that I purchased new and drove for many years. The truck mostly has sat idle for the last few years and is only cranked occasionally. I recently tuned the truck with new plugs and wires and everything seemed to be working fine. I went out a month ago and the engine would turn over, but not fire up. Last week, I tried to crank the truck again and it would not turn over at all. I have tried two different batteries and get the same result. The symptoms of the current problem is when I install the battery, the buzzer will sound when the key is inserted. However, when you attempt to turn the key to crank the engine, the buzzer will quit and it seems as if everything has died (no power). The only way to get the buzzer to come back on is to disconnect the battery and try again. seems like some relay may be bad, but not sure really were to start. Any help would be greatly appreciated. Thanks in advance.
Morris
bradform is offline
post #2 of 5 Old 11-13-2011, 03:51 PM
Quoted: 4 Post(s)
Does it do it if you only turn it to the run position?
Does it still do it if you disconnect the small wire going to the starter?
sometoyotaguy is offline
post #3 of 5 Old 11-13-2011, 04:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
It only does it as I turn the key to try to crank the truck. It buzzes as usual when I insert the key and when it is turned to crank, the buzz stops and will only come back if I reset the battery by removing and reinstalling the battery terminal. It almost seems like it shorting out some where. Have not messed with the small wire on the starter.
bradform is offline
post #4 of 5 Old 11-13-2011, 07:11 PM
Wicked Clown Juggalo
cd_god's Avatar
Quoted: 0 Post(s)
Does it start with jumper cables? Check for corrosion between the bettery posts and the terminals.
cd_god is offline
post #5 of 5 Old 11-14-2011, 09:13 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Had to go out of town for a few days, so I won't get to it until this weekend. I will check and clean all wires, as the truck has set for some time and corrosion could be the culprit. Thank you to all for your help. I'll let you know what I find this weekend.
bradform is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
