hard to put into gear - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 7 Old 01-24-2012, 02:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My 89 has recently begun having an issue with going into 1st gear at a high idle. If I put it in 2nd and let the clutch out enough to drop the RPM's I can then get it into 1st. However, once I begin driving and the engine drops to normal idle RPM's I can put it in 1st gear with no problem. Also, it shifts great it is just an issue with 1st gear at high idle. Anyone have any ideas on why and how to fix it.
jessup911 is offline
post #2 of 7 Old 01-24-2012, 03:28 PM
Quoted: 0 Post(s)
at what point does the clutch grab? at the bottom?
lean under the dash, and take a peak at the mastercylinder, check for leaks. it sounds like it might not be fully releasing. either due to a leak, or it being out of adjustment.
nevada is offline
post #3 of 7 Old 01-29-2012, 11:54 AM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
^check that. That's my first guess, that it's not releasing all the way. Could be as simple as trying to engage gears too soon after pushing the clutch in and the gears are still spinning at different speeds (though this would be more of a 'didn't notice before' kind of thing)
Try pumping the clutch before engaging 1st.
Try holding the clutch in for a few seconds before going to 1st.
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
post #4 of 7 Old 01-29-2012, 11:34 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
Check clutch lines for leaks, bleed the slave cylinder, and add fresh fluid to your master cylinder.
Does it shift fine? No need for a new shifter bushing, correct?
What's your gearbox fluid?
94 RN93 | *dead* | W58 | 2WD8"V6 | FX-R3.0 5000K 35W| 18x10.5 295/30/18
95 JZA80 | V160 | HKS Intake, Hipermax IV GT, & 4" Ti | RMS SS 3" DP | Bride Stradia | Nardi
89-95 Hilux Massive Truck Info
IronNam is offline
post #5 of 7 Old 01-30-2012, 07:12 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for all the suggestions but it turns out all I had to do was adjust the clutch.
post #6 of 7 Old 01-30-2012, 09:19 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
just the pedal?
Glad it worked out, man
IronNam is offline
post #7 of 7 Old 01-31-2012, 04:58 AM
Languishing in Virginia
TNRabbit's Avatar
Quoted: 0 Post(s)
Make sure our clutch bracket under the dash hasn't cracked. Common problem. It's only visible when you have the clutch depressed, usually.
TNRabbit
STOCK '94 DLX XtraCab 4x4, 5 spd, 3VZE, 270,000 mi.
TNRabbit is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
