1992 automatic trans reverse light switch location - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 8 Old 04-04-2012, 08:48 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have search entirely and coudnt find anything about the location of reverse light switch of a 1992 pick up 2wd automatic transmission. I have looked at the passenger side of transmission and find a hex nut but there is no wires attached to it or even a connector on the top of the hex nut, I looked at the driver side of the tranny and find something with a single wire attached to it but its not a hex nut, could anyone help me out wheres the location of my back up light switch? need your help please.
ledperry is offline
post #2 of 8 Old 04-04-2012, 09:34 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Anyone? help please...
ledperry is offline
post #3 of 8 Old 04-05-2012, 06:25 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
2 days and 90 views not a single reply... anyone out there whose kind enough to help.
ledperry is offline
post #4 of 8 Old 04-05-2012, 08:20 PM
Tech1984's Avatar
Quoted: 7 Post(s)
It's part of the neutral safety switch. (PNP) switch. This is the part that moves on the side of the trans when going through the gear selection. Usually with a large electrical connector attached to the top.
Are your reverse lights not working? Try giggling the shift lever in R range to try and get them to flicker. If they do, then it's the switch which could be just cleaned and returned to service.
Bin wrenchin' on the Yota's since '84
30th anniversary 2014
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline
post #5 of 8 Old 04-06-2012, 06:47 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks Tech1984, is this PNP switch the one on the passenger side of the trans or the driver side of the trans? I found one screwed on the driver side of the trans with only one wire attached to it, while the one on the passerger side is also screwed but kinda big and flat with a big connector on top, just want to make sure which one.
ledperry is offline
post #6 of 8 Old 04-06-2012, 07:04 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Also what part of the neutral safety switch to clean? do I need to remove it completely?
ledperry is offline
post #7 of 8 Old 04-06-2012, 03:56 PM
Pochacco Owns Me
atobe's Avatar
Quoted: 0 Post(s)
It's the big one with may be 6-9 wires going into it. You take it out, take it apart then clean the contacts inside.
Removing and cleaning the Neutral Start Switch this is for a camry but it's simliar.
atobe is offline
post #8 of 8 Old 04-09-2012, 02:33 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I found the neutral switch, i removed and cleaned all the contacts as well as the connectors, I sprayed the connectors with electronic cleaner but still my reverse light is not working. What could be the problem?
ledperry is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
