What size tires fit 92 pu standard rims?
Hi all.
I have always run P195/75 R14 tires (standard steel Toyota rims) on my 92 base 2wd, but need some low-cost replacements. I have a used set available, but two are P195/75 R14, and two are P205/75 R14. Would these larger tires fit the rims safely? Obviously the larger ones go on the back..any problems with these size differences? The 205 just means they're slightly wider, but they should fit the 14 inch rims, right?
Thanks in advance.
1992 Toyota Pickup, base, 22RE, 5-speed, 137,000 miles.
