1990 Pickup with idling problems... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 06-23-2004, 11:32 AM   #1 (permalink)
View Lee280zx's Photo Gallery
I have a 1990 Pickup 4 cylinder with the 22RE engine and automatic transmission. It has just 42,000 miles on it. It has been tuned up recently.
The problem I'm having is that when I'm idling with the A/C on and my foot on the brake, the engine idles very roughly, like the RPM is going up and down.
If I remove my foot from the brake or turn the A/C off, the problem disappears immediately every time.
I'm thinking this is some sort of vacuum issue since both the A/C and power brakes have vacuum components, but I would like some ideas about what to check.
Does anyone have any advice/suggestions?
Thanks
Lee280zx is offline   Reply With Quote
Old 06-24-2004, 04:07 AM   #2 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
I got a '86 4runner, 4 cylinder with the 22RE engine and automatic transmission. They should be pretty close. On top of the valve cover there is a solenoid (1 plug, 2 hoses). This energizes when the a/c is turned ON. Goes to a diaprahmed valve (4 hoses) mounted on the intake manifold. This valve has a plastic screw that will adjust the idle (out is rev up) when the a/c is ON. Make sure the solenoid is energizing when the a/c is turned ON (you can feel the click) and check the associated hoses for splits/leaks.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline   Reply With Quote
Old 06-27-2004, 11:11 PM   #3 (permalink)
View brokentoy's Photo Gallery
cheack your vaccum lines for any craks , weather checking, or abnormalities, i recently set the overhead on my 94 22re and it did the same thing. forgot to plug in the vacuum lines to the power steering pump
4wd, it helps ya go, but it won't help ya stop
brokentoy is offline   Reply With Quote
