22re rebuild recommendations? - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 16 Old 08-19-2012, 09:36 AM Thread Starter
1994 Toyota 22re 2wd 5sp
Quoted: 0 Post(s)
(Thread Starter)
Looking for someone to rebuild my 1994 22re. It has a blown head gasket and the engine seems to be making noise from bottom end. Can anyone recommend someone in the triad area of NC?
_____________________________
1994 Toyota STD 22RE 2WD 5 SPEED
ravenr106 is offline
post #2 of 16 Old 08-19-2012, 10:02 AM
Quoted: 0 Post(s)
im in the greensboro area ,the last one i had done was a bout 5 maybe 6 years ago and i had it done at toys unlimited , not sure if they still open or not tho , i wanna say there in liberty , like i said been a while since ive been there ,
94yotadaily is offline
post #3 of 16 Old 08-19-2012, 10:52 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
ok I'll give them a call. do you remember about how much they are getting to rebuild one?
post #4 of 16 Old 08-19-2012, 11:28 AM
Quoted: 0 Post(s)
not right off hand , i went to them because of alot of friends of mine recomended them , they did do me a really good job and the guy i sold the truck to still driving it daily , im sure there are more in the area , i just know ive used toys unlimited before .........ill see if the guy i sold the truck too still has the paper work on monday
post #5 of 16 Old 08-19-2012, 10:18 PM
Helium-3 is the answer
LeftCoast's Avatar
Quoted: 1 Post(s)
Whatever you do, make sure they use the metal guide (steel rail) for the timing chain instead of the stock plastic one, and I'd also make sure they check/replace the timing cover...they wear thin due to the timing chain slapping on them (due to the shitty plastic guide).
http://www.engnbldr.com/toyota-ala-carte.html
1992 Toyota Pickup, 2WD, base, 22RE, 5-speed, 144,000 miles.
LeftCoast is offline
post #6 of 16 Old 08-20-2012, 05:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
There is a guy in kannapolis,nc that advertises a rebuilt engine for $600. I called him today and he said he could rebuild mine, resurface the head, new oil and water pump, new timing chain, and install it back into the truck for total $1300. Does that sound like a good deal?
post #7 of 16 Old 08-20-2012, 08:16 PM
LeftCoast's Avatar
Quoted: 1 Post(s)
My friend just spent $3000 for his '87 22RE...$1300 seems light, but it is a tough economy for everyone. I'd check warranty and BBB info.
post #8 of 16 Old 08-21-2012, 05:42 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I havent checked with the BBB, but he offers a 2 year/24000 mile warranty.
post #9 of 16 Old 08-21-2012, 08:23 AM
Quoted: 0 Post(s)
he couldnt find the paper work , sorry .......
post #10 of 16 Old 08-21-2012, 09:31 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Has anyone ever heard of a cracked head on a 22re? My dads mechanic said that he has never seen one with a blown head gasket, that it has always been a cracked head. Its only using about a cup of coolant a week and the oil isnt milky so he said it wouldnt hurt to drive it alittle while longer.
post #11 of 16 Old 08-21-2012, 12:24 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Here is Poteats ad, hes in kannapolis to.
We have 22re and 22r engine available for sale. All engine are sold on exchange basis. Your engine will come with new pistons, rings, main bearings, rod bearings, thrust washers, HD timing sets, oil pump, and complete gasket set. We use only the best parts wich include Sivolite Pistons, Perfect Circle/Hastings rings, Clevite bearings, DNJ Heavy duty timing, these timing sets have a metal insert in the guide to prevent breaking, melling oil pumps, and victor reinz gaskets. These are the premier engine parts in the after market. Your engine will also come with a 2yr/24k warranty. $800
Sound like a good deal?
post #12 of 16 Old 09-04-2012, 03:32 AM
Innocent Bystander
Quoted: 0 Post(s)
800 is one of the cheapest prices I have seen, I am in the market myself..... But i haven't decided on a rebuild or buying a reman engine.
If someone can vouch for the quality of those engines I may have to go see this guy.
Jeremy_C is offline
post #13 of 16 Old 09-04-2012, 05:58 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Poteat seems to have good reviews. I've checked on the internet and on other forums. I called him the other day and he has a couple 22re's ready to go for $936. That is with a new head. A little cheaper if you use your old head. Also, comes with metal backed guides for timing chain.
post #14 of 16 Old 09-10-2012, 07:54 AM
GVX
Quoted: 0 Post(s)
If it sounds too good to be true it usually is. I recommend Jasper Engines and Transmissions 3 year 1000,000 mile warranty (anywhere you might be traveling and no hassles) look on there web sight or call them and ask for one and use one of there preferred installers after all you get what you pay for. I just looked it up $2436.00 If you don't want gamble and pay out again in the near future pay a little extra. After all in most warranty's the deck is stacked.
GVX is offline
post #15 of 16 Old 09-10-2012, 08:13 AM
GVX
Quoted: 0 Post(s)
I reciently just built my own engine with all the best parts which were mostly DNJ and Japan parts (not Chinese) (wholesale from engine builder in Oregon) I spent 0ver $500.00 (probably 8-900 at autozone) on just the parts and $380.00 on the machine shop $800.00 doesn't add up. If you are not capable of building your own engine I still say go with a Jasper If you can find an installer that charged labor only you can probably get the engine for under $2000.00
GVX is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
