Tire pressure questions? - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 6 Old 11-23-2012, 02:48 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I have a 1992 pickup base model. The original tires were 195 75R 14, but when I bought it the tires were and are 205 75R 14. The label on the door jam says that the correct psi is 35 cold. Is 35 psi the correct pressure for the 205 75R 14 tires also? Does recommended psi vary by tire size? I am about to move my belongings with this truck. When I do should I add more psi to the rear tires? Thanks for any replies?
John999 is offline
post #2 of 6 Old 11-23-2012, 02:50 PM
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Quoted: 239 Post(s)
35 psi is plenty of pressure for anything that truck is capable of. Modern tire construction makes tires a lot more stable than they were when the truck was built. Even so, it would not hurt anything if you wanted to bump up the rears a bit in pressure when you are fully loaded.
You should be good to go!
03 Camry - 09 XB - 07 GMC Sierra - 14 Accord Sport
Zembonez is offline
post #3 of 6 Old 11-23-2012, 04:35 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 196 Post(s)
Yes
No, pressure is pressure. A larger tire requires a larger volume of air, but suggested pressure would be the same.
But different tires from the stock ones might work better at a different pressure, you can always vary the pressure to see what works best.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #4 of 6 Old 11-23-2012, 05:07 PM
Got Snow?
05Moose's Avatar
Quoted: 1057 Post(s)
And the chalk test is really your only way to know for sure. Luckily, my gas station tends to drop a lot of chalky powder down some mornings for a free chalk test.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline
post #5 of 6 Old 11-25-2012, 08:52 AM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
If you're loading the truck up, inflate the tires to their stated limit as their load ratings on the tire are for that pressure.
too low pressure WILL cause handling problems, wear problems, heat problems, damage, and blowouts.
too high pressure (within the rating of the tire) may cause slight, almost unmeasurable loss of traction (till you get crazy overinflated), and a harder ride.
After working in a shop and 2 dealerships for several years I've seen 2 examples of tires with stereotypical center (overinflation) wear pattern. Both were on ford rangers (which are even lighter in the back than our trucks despite being heavier overall) that never rotated the tires. I've seen over a dozen examples of cars with underinflation wear that the owners religiously kept the tires at the door-sticker pressure.
over/underinflation is a function of how much it's carrying. if going to a wider tire, yes you do lower pressure *slightly* to be textbook perfect. in the real world, the difference is less than the difference between brands. speaking of which, I've seen cheap tires more than 2" narrower tread for the same size than a high quality tire. on the same vehicle, the cheap tire is bulging out and almost riding the sidewall at HIGHER pressure than the good tire at "proper" inflation (When I worked in the shop: 235/75r15 (stock for dakotas, 4wd S10s/blazers, rangers, etc) mastercraft AS/4 vs any Cooper Discoverer
Also remember that the number on the door jamb is COLD inflation and accounts for heating during driving. including driving down the highway for hours when it's 100f out. My Cressida's owner's manual even say "for extended highway driving, increase cold inflation pressure to 35 psi"(from 31 or 32)
All said and done, tires are overengineered by a huge factor. When you see people putting 6k lb SUVs on 2 wheels and driving down the road, they're usually inflated to 90+psi (or so I've read in a few places that talk about it). If they weren't, they'd blow out every time you ran over a pebble
Oh, and make sure your spare is inflated too. I lost track after a week in the shop of how many people's spare tire had zero pressure in it. Take a wild guess how useful that is.
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
post #6 of 6 Old 11-26-2012, 03:42 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks for all the info. This forum is awesome.
John999 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
