Clutch and Brake Master Cylinder Leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 12-06-2012, 12:31 PM   #1 (permalink)
View Herkdriver's Photo Gallery
The rubber/plastic "lids" on my brake and clutch MCs seem to be venting. They're both damp with fluid. Anyone else have this problem? I assume they're supposed to be bone dry on top?
Sent from my iPhone using AutoGuide.com Free App
'89 xTra cab
4x4
SR5 / AC
3vze / 5 speed
152,000 mi.
Herkdriver is offline   Reply With Quote
Old 12-07-2012, 09:01 PM   #2 (permalink)
Soylent Green sales
fourwd1's Avatar
Gameroom cash: $768055
View fourwd1's Photo Gallery
You assume correctly.
Fluid isn't leaking is it?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 12-09-2012, 01:18 AM   #3 (permalink)
Senior TN Member
Gameroom cash: $577665
View jetwhine's Photo Gallery
Is your fluid level too high? Above the full line?
jetwhine is offline   Reply With Quote
Old 12-10-2012, 10:28 AM   #4 (permalink)
Cressida nut
Gameroom cash: $436395
View kamesama980's Photo Gallery
have you filled them recently? have you had brake or clutch work done on the truck?
remember when you do so not to go over the full mark. it needs some expansion room as the fluid moves back and forth. If you fill it all the way up, it will frequently spill over.
-Russell
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 12-10-2012, 04:02 PM   #5 (permalink)
I had the rear brake cylinders replaced recently. And yes, the fluid I's slightly above the full mark. I'll remove some fluid and see what happens. The clutch reservoir is below the max line. I'll take some out if that one too. Thanks for the responses.
Old 12-11-2012, 04:58 PM   #6 (permalink)
Fluid levels are now just below the max line. I'll see how that goes once I get my CEL Code 24 issue worked out.
'89 xTra cab
4x4
SR5 / AC
3vze / 5 speed
152,000 mi.
