92 toyota steering problems - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 7 Old 12-29-2012, 01:41 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The steering on my truck has become limited on how far I can turn the wheels. It sometime feels a little jerky when you are cranking it hard to turn. .There is some oil that has sprayed the passanger side wheel well. Any idea what could be causing the limited steering?
Thanks
Weatherby is offline
post #2 of 7 Old 12-29-2012, 07:29 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 213 Post(s)
If you have power steering, I'd start by checking the fluid level in the reservoir.
No THANKS necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 7 Old 12-30-2012, 06:37 AM
Cressida nut
kamesama980's Avatar
Quoted: 66 Post(s)
Check the fluid first.
does it stop like it's binding or do you just lose power assist? try turning to the lock while the trucks moving. try jacking up the front end and turning the wheel with the engine off (and on)
-Russell
"You don't get to judge me for how I fix what you break"
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
kamesama980 is offline
post #4 of 7 Old 12-30-2012, 02:16 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Topped up the power steering fluid...so thats all good. It is binding...not losing any power when turning. I just took it for a drive...its making a few funny noises...especialy when it is in 4 wheel It sounds like a rubbing grinding noise. When I park the truck with the steering cranked I cant see anywhere it is rubbing.?
post #5 of 7 Old 01-01-2013, 07:36 AM
Cressida nut
Quoted: 66 Post(s)
What was that funny named part....gotta look up an old thread now.... ah yes, here it is: Evans Creek won this round...
Birfield joint
-Russell
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
post #6 of 7 Old 01-01-2013, 09:10 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Birfield joint
Hey Kamesama,
My truck has the IFS. Would the CV's effect steering? The sound when I crank it hard to the left is a crunching....then rubbing sound. As you can tell by my diagnosis...I am a rookie.
post #7 of 7 Old 01-02-2013, 08:00 AM
Cressida nut
Quoted: 66 Post(s)
Originally Posted by Weatherby View Post
Hey Kamesama,
oh, ha, yea...IFS doh
How does it drive in 4x4? should be jerky and making noise even going straight in 4x if the CVs are causing it to bind. Should but not always.
You could also leave it in 2wd, lift the front, and try to turn the wheels and CVs to see what/where is binding. If it's the CVs it'll get harder to spin the shafts the greater the articulation angle. Or you'll feel it binding/moving/etc.
-Russell
'03 Subaru Baja
'01 BMW R1200C
'90 Toyota Cressida
'70 VW Bug
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
