I run a 94 single cab truck 22re. The timing chain broke.I replaced it and the guides.It fired up when reassembled but died after the engine reached operational temp.If I hold the throttle it will run a lot of tapping, vales I think, Any suggestions would be most appreciated. thank you.
Well, it sounds like the valves may need adjusting (if they're adjustable). If they're hydraulic, then it sounds like after the engine heats up, they lose pressure.
I don't know if your truck has valve adjustments or not, but that can easily be one culprit.
If they're hydraulic, try running a thicker oil that won't drain when it gets hot.
Thank you Black Omega, I don't know if the valves are adjustable but I'll pull the valve cover and check, is there anything else I can do while I have the valve cover off? I currently run 10 w 40 Gastro, what Oil would you recogmend?
I tried to adjust the Idle at the throttle body and the engine wouldn't respond to the change turning the screw made no difference am I missing a step some where?
thanks again
You could check the cam timing. Start with the basics first before you twiddle with everything else randomly hoping to fix the issue.
When the engine is at Top Dead Center, the dot on the cam sprocket should be positioned slightly off toward the driver's side of the vehicle.
'92 ST185 All trac turbo
'91 Cressida
'72 TE27
The Following User Says Thank You to DCM For This Useful Post:
thanks DMC , if that's the case do I have to pull the timing cover again or is there a less involved fix? It's been a good little truck so I want to get it right. Is there some way to test to see if I get the chair right before closing it up?
thanks again
thanks again
I suppose the pertinent quesion is how did it run before you replaced the timing chain?
How many miles on the engine?
If the valves are adjustable, when was the last time it was adjusted?
Regarding oil, what does the manual call for? You can't run thicker oil in cerain engines because the lifter holes are metered to certain weights of oils. For instance if you change the oil on a Taurus that calls for 5w20 and use 5w30 in its place, the valvetrain will clatter.
So it really depends. However, most engines have a variety of oils they can run depending on ambient temperature.
The last one that also matters is how do you drive? Realistically. Don't say you drive like grandma when you're between 3500 and 5k most of the time. That reason alone is the most important. If you drive spirited, it's better to run a thicker oil.
In most of my cars, especially ones with higher miles, I've always ran Catrol Syntec (Edge, whatever they call it now)5 w 50.
On most days I will hit the redline on a car. Not all the time, but often enough to where I need a slightly thicker oil. I've never had a problem with it, and even on some older small block Fords (302, 351, 289, etc.)it brought down operating temps.
Definitely recheck the timing, however, we don't have enough info. As mentioned above, if it is supposed to have a valve adjustment done, and hasn't had it done, it can easily cause running problems.
My friends Civic dropped a cylinder completely.
Perhaps he was trying to fix a noise in the valvetrain the whole time and thought that maybe the chain was stretched and out of time.
thanks again
To answer the first question, no. Remove the valve cover, then set the crank 0° (so that your #1 valves are both closed). Then check to make sure the sprocket is timed. If it isn't, you can adjust without removing the cover, just takes a bit of common sense and elbow grease, and some patience.
Black Omega, although checking the valve lash etc is a good idea, you have to look at the work that was done by the person. If it wasn't done 100% right, there really is no sense in setting the valves until he's certain that the cam is timed properly, I'm sure you'd agree and can see the logic in checking it first.
'91 Cressida
'72 TE27
Presumably, since this is the pickup section and the V6 has timing belts, the OP has the 22RE. It has a purely mechanical rocker valvetrain, no hydraulics to get funny with different weight oils. No offense black omega: thanks for the help but it's not helping too much.
Forget oil weight, 10w30 is right. forget lifters, there aren't any. If it wasn't making this noise before, it's not the valve adjustment. 1. Check the cam as mentioned. If the cam is where it should be, then check the ignition timing with a timing light. (short TE1 to E1, should be about 5 deg BTDC. If it isn't, someone may have previously adjusted the distributor to compensate for chain problems.
That the idle screw adjustment isn't making much difference could also be a problem, but check the other stuff first.
-Russell
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
The Following User Says Thank You to kamesama980 For This Useful Post:
Of course I can. However, you can check the timing and adjust the valves at the same time. That way you can ensure that the poor running is not related to improper lash.
Although if the chain actually broke on him, how do we know there isn't more damage internally? Is that an interference engine?
None taken.
Is that 4 Banger an interference engine?
At this point instead of assuming and fiddling with shit, adjusting the valves and checking compression is what I'd do. For several reasons.
1. You can immediately tell if there is an issue if there's low compression.
2. You'll have an opportunity to inspect the plugs.
Once you've verified that everything is in spec, THEN move on to checking timing and idle adjustment. Although the idle should never have to be adjusted.
Thanks for the direction I'll pull the value cover and check it out
, I'll be back to thank you later or beg for more advice.
If the chain is off one tooth how would you move it with out pulling the timing cover?
Thanks for sharing the knowledge.
, I'll be back to thank you later or beg for more advice. If the chain is off one tooth how would you move it with out pulling the timing cover?
You can't. If it's off a tooth, you'll have to pull all back apart and reset it.
If you verify that it is off, reset it and remember to check it by turning the engine over 2 full revolutions and making sure the timing marks line back up.
I've done it a couple of times without removing the timing cover but it's a pain in the butt to do. You'll need to use a slender bar or large screwdriver to hold the sprocket up while undoing the cam bolt. Remove the distributor drive gear and thread the cam bolt back in enough that there's abou a 1/4" gap between the flange of the bolt and the sprocket. Slide the sprocket forward til it drops onto the bolt, then adjust the chain 1 tooth in whichever direction it needs to go, then take a piece of wire and tie the chain in place through one of the openings in the sprocket, so you don't forget which tooth it's supposed to be on. Now the difficult part...with your big screwdriver/prybar or whatever you use, lift the sprocket back onto the snout of the cam, and at the same time, turn the crank pulley until the sprocket lines up with the alignment pin. Remember you'll be working against the tensioner when doing this. If you're not comfortable doing it this way then you'll need to remove the timing cover and do it that way.
'91 Cressida
'72 TE27
Wow you know this engine well.
My chain has two shiney links one goes to the crank dot and the other to the cam dot.
The cam dot should rest in the middle of the link is that correct?
Should the crank be at 0 TDC or at 5 degree timing mark?
Are there other indicators that will indicate the chair is timed incorrectly.
DMC , Black Omega thanks for taken time to help out
