89 Pickup is dead - Good Battery no juice - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 08-18-2004, 01:22 AM   #1 (permalink)
View cepolsonaz's Photo Gallery
Question 89 Pickup is dead - Good Battery no juice
My baby(Truck) was hesitating on acceleration, troubleshooting guide said it may be a bad fuel filter. Changed that and it cleared up quite a bit but still a little sluggish at times. Lived with it for a week then it just died. Battery tests good but I get nothing - No Lights, Nothing. It's like the battery is dead but it's not. I checked all the fuses - they are all good.
What can I do? Where else do I look? I don't know of any fusable links?
If any one can give me some direction I would be appreciative.
It's a 4cyl 22FE EFI 1989 Pickup Truck. Thanks in advance....
cepolsonaz is offline   Reply With Quote
Old 08-18-2004, 01:43 AM   #2 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Have you checked the fuses under the hood by the battery? My '86 4runner has a '+' to the starter and a smaller wire to this fuse box. Make sure you have 12V in and out. 12V out of there should feed the inside fuse box.
texas12 is offline   Reply With Quote
Old 08-18-2004, 08:54 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
check your contacts to the battery. also there are some fuses in the cabin. and try switching out the battery for another. some times they test good but not good enough for the car. also to you sluggish get a bottel of injector cleaner and that should help a bit. try and find some sea foam and dump a whole can in dont pay attention to what they say to use more = more cleaning power.
^ and leaving it that way!
Old 08-23-2004, 07:16 PM   #4 (permalink)
View 89'TOY's Photo Gallery
Hey, I have an 89 pickup that had the same problem. Check the alternator, thats what was shot in mine.
89'TOY is offline   Reply With Quote
Old 08-24-2004, 04:55 AM   #5 (permalink)
View yoder-bug's Photo Gallery
well i had a simeler problem it was the main body ground by the battery it was broke it made the truck have no light or nothing tryed to hold it to the ground and when it wasnt getting good ground it was missing real bad
ldm
yoder-bug is offline   Reply With Quote
Old 08-25-2004, 04:12 PM   #6 (permalink)
Sleeping While Awake
View 94 Yota's Photo Gallery
like 89 toy said, check your alternator, also, check the + and - cables, look for any corrosion on them and check the battery posts if they need to be cleaned.
94- 22RE, 5spd, 33x12.50, Engbldr 261 cam
To Come:
5.29's, rear E-Locker, front tru-trac, 35's, Bobbed Bed,
blah blah blah
94 Yota is offline   Reply With Quote
Old 11-03-2004, 04:54 PM   #7 (permalink)
View 91toyindiana's Photo Gallery
put some jumper cables on the battery and see if u can turn any lights on or the radio.. at least some kinda power if not then first thing i would do is put new terminals on it and wires.. there not that expensive.. its gotta be simple as far as getting power to it.. and you can get a haynes book at any auto store it has complete wiring diagrams and its kinda simple compared to most vehicles the electrical system
91toyindiana is offline   Reply With Quote
Old 11-03-2004, 08:36 PM   #8 (permalink)
View Billy_The_kid29's Photo Gallery
I have an 86 pickup make sure u have two possitive wires connected.I kno it sounds strange but there are two possitives
ottawa canada
Billy_The_kid29 is offline   Reply With Quote
Old 11-04-2004, 01:46 AM   #9 (permalink)
check the circuit opening relay
locate the relay by removing the right side kick panel the glove box and speaker..
Old 11-04-2004, 01:48 AM   #10 (permalink)
22re problems
Old 05-15-2008, 07:31 AM   #11 (permalink)
KathyLue's Avatar
View KathyLue's Photo Gallery
car wouldn't go anywhere...it turned out that the wires that connect the battery to the engine... were totally corroded. New ones solved the problem.
KathyLue is offline   Reply With Quote
