First, are you sure it is a 22RE? The "E" means it is fuel injected. If it is not injected, you should have no problem rebuilding the carb. My experience rebuilding carbs is similar to yours. I went through the carb on my daughter's '87 with only one minor problem. As I recollect, the automatic choke did not function properly. I did not pursue the problem because the weather doesn't get very cold where we lived then. I would recommend you find a shop manual (preferably the factory manual) before you start, though.
