4x4 Lifting question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 01-04-2005, 09:41 AM   #1 (permalink)
View Blue Dude's Photo Gallery
Cool 4x4 Lifting question
OK I have a 93 toyota 4x4 4 cyl, that I currently have a 2" body lift with 33"x12.5" Tires on it. I was wandering if I cranked the torsion bars in the front and put lifting shackles on the back maybe 1.5" or 2" lift....if there would be anything I would have to do to the brake lines or anything else? I just got done redoing the exhaust and want to bring the back end up higher to make the truck more level as it sits lower than the front. The torsion bar deal is if I wanted to do it in the future for now I am just thinking about the shackles.
Thanks
Blue Dude is offline   Reply With Quote
Old 01-05-2005, 08:00 AM   #2 (permalink)
bump
Old 01-03-2007, 11:37 PM   #3 (permalink)
View kawaboy14's Photo Gallery
did you put the body lift on yourself? and did you have to cut your fenders for the 33's?
kawaboy14 is offline   Reply With Quote
Old 01-08-2007, 11:38 PM   #4 (permalink)
Lemon Jelly Donut
rivethed's Avatar
View rivethed's Photo Gallery
ok, be wary of cranking the torion bars too much to gain suspension travel/lift. if they are torqued too much, the severely affect the ride qualities, especially if they are resing on the stops. And when you bounce out of a hole or dip, the suspension extends when you leave terra firma, and it is not to healthy on the front end. Also, the CV angles can become too extreme. Prepare to replace your CV boot twice as often.
i used to run my (how does pee_cup say, 3-veezy) torsion cranked up to about 3/4 inch off the upper a-arm bump stop. not too abd on the streets, alignment guys hated it, and my CV's boots wore through in 10 monthes from the angle. I dropped them down, and my last set of boots lasted untilI tore one on a rock.
Just some thoughts base on my own experiences.
"These are my experiences, yours will vary!"
06 Taco AccessCab, 4.ohhhh, Prerunner Sr5
93 xtra cab "pig pen" (sold, /me pours the "red stuff" out in remembrance)
?? ISO the next project
rivethed is offline   Reply With Quote
Old 01-13-2007, 09:10 AM   #5 (permalink)
View gray9422rte's Photo Gallery
crank ur torsin 10 turns you will get about 2 inches and everything else will be fine
gray9422rte is offline   Reply With Quote
Old 01-13-2007, 11:05 AM   #6 (permalink)
Vicoor's Avatar
View Vicoor's Photo Gallery
the body lift would not have affected the brake lines between the frame and suspension. Raising the torsion bars will only move the suspension with in the stock limits so that won't be a problem. Raising the rear suspension with shackles will allow for more extension than was designed for so you should check the rear brake hose to make sure you are not stretching it with the suspension fully extended.
As was mentioned before, jacking up the front that much with the torsion bars will adversly effect the ride and handling.
Don't talk about it, Just do it!
22RE, xtreme ported head, crane cam, cust manifold, MegasquirtII-Extra(full sequential inj/spark), 300cc inj, adj reg, supra fp, LCE header, W58, short throw shifter, 14lb flywheel, kevlar clutch, 4.10 gears &Truetrac, drop spindles...
Vicoor is offline   Reply With Quote
Old 01-13-2007, 04:14 PM   #7 (permalink)
www.bodybuilding.com
95toybox's Avatar
View 95toybox's Photo Gallery
I would suggest not moving the torsion bars. I did that on my 91 and I had tons of alignment problems and the ride was not good at all. Like Vicoor says if you decide to raise it that way make sure to check the brake lines because I didnt Had to do some replacing after that.
1995 DLX, Ext Cab, LCE pro short block, lce pro performer cam, alum. rockers, LCE header, pro flow exhaust, lc stage 2 head, lce throttle body,downey CAI, optima yellow top, H4, 5 inch lift, 2"BL, 35x12.5 Xterrains, Pro comp 1079, BJ Spacers, All pro shackles http://www.cardomain.com/id/joshp01
95toybox is offline   Reply With Quote
Old 01-13-2007, 09:15 PM   #8 (permalink)
Bring On The MUD!!!!!
Geius Maniacal's Avatar
View Geius Maniacal's Photo Gallery
how do you have 33's with a 2in body lift?? if you can avoid it, dont crank the torsions. if you really want that small amount of lift, go ahead, but know the dangers of it! i would say, just save some money to buy a 4in susp. lift. then, either take out your body lift or leave it it, whatever you prefer.
Cam
!!!SOLD!!! '83 SR5 w/ Cummins 4BT Turbo Diesel *Under Cons.* 6in Susp. and 3in Body lift on 35's
'99 Dodge Ram 2500 5.9L Cummins BD Super-B, CDT2, Custom 47RE, Adrenaline w/ Pulse, BD Hot Rod VP44, Airdog 165, BD XXX-Pulse 125's, Isspro EV2's
Geius Maniacal is offline   Reply With Quote
Old 01-14-2007, 08:31 AM   #9 (permalink)
Banned
View ovrrdrive's Photo Gallery
I cranked my tbars 11 or so years ago when I got my big tires and it's been fine ever since.
Compared to my 94 standard cab, the xcab sat lower and rode a lot mushier, and the tbar crank gave it a much nicer ( IMO ) ride. Of course I didn't max them, but rather I tried to go about halfway to the max. If I recall I cranked one side like 8 turns, and the other like 14. Don't ask me why they were uneven, but I was measuring to the front cross-member and that's what it took to get it right. The alignment tech laughed at me and said I would have to pay to get it evened up if it was wrong, and he got out his tape measure and agreed that it was perfect even though the lower arms were at different angles. After the alignment everything has been perfect ever since.
And my stock CV boots have lasted until this year, and 208k miles. I'd say that pretty much negates the argument that cranking the bars will put extra stress on them. I'm just now up for replacement and even now its just the drivers side making noise.
ovrrdrive is offline   Reply With Quote
Old 01-14-2007, 08:08 PM   #10 (permalink)
7MGTE/22RE
shaeff's Avatar
View shaeff's Photo Gallery
ovrrdrive- you have no other suspension/lifting modifications to fit the 33x12.5's? (other then the tweaked torsion bars?)
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline   Reply With Quote
Old 01-14-2007, 08:24 PM   #11 (permalink)
Banned
subliminaltrips's Avatar
View subliminaltrips's Photo Gallery
32x11.50....
subliminaltrips is offline   Reply With Quote
Old 01-14-2007, 10:22 PM   #12 (permalink)
Banned
I did put the 32x11.50's on with just the tbar crank and they rubbed pretty badly. It was driveable, but it rubbed enough that it ripped off a mud flap.
With the 3" BL and the tbar crank, I could easily run 33x12.50's on the truck, but I have decided to do a 4-5" suspension lift and 37x12.50 Iroks in a month or so.
Then of course I'm gonna have to regear too... It's time to tighten the old belt...
Old 01-14-2007, 11:53 PM   #13 (permalink)
Lemon Jelly Donut
rivethed's Avatar
Do you have Auto or Manual hubs Ovrrdrive??? This also makes a difference. manual hubs, you will not notice the wear as the joints are only in motion when the hubs are engaged. but with the ADD style hubs, the cv's are always turning, and with excessive torion crank, which cause extreme CV angles, you will rub/wear the boots out sooner, in my experience. plus, you stated, you have only gone up (estimated) halfway. So many people crank them to extremes, adn it makes touble. I know, I thought that way when I first got my 3vze, and shortly learned it was bad idea. But to each his own. We just share our experiences here.
Let us know how the 37's run, are you gonna go 5.29 with that much meat to turn??
Old 01-15-2007, 04:41 AM   #14 (permalink)
Banned
I have the el cheapo model truck. Manual transmission and hubs.
I've seen trucks that had the tbars pinned and I can't believe people drive them that way. The front end won't flex at all that way...
When I first started planning the build up I'm gonna do I was considering 5.71's but after a little more reading and planning I'm thinking the 5.29's should be plenty. I'll be going from the 32's to 37, and from 4.10 to 5.29 so that should be more than plenty. I just don't want to do anything to make the truck any slower than it already is...
And you can expect lots of pics and a writeup for sure.
Old 01-15-2007, 06:44 AM   #15 (permalink)
Banned
i expect a phone call when you start....
