91 Pickup Dash lights - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 02-24-2005, 11:33 AM   #1 (permalink)
Idaho Native
View Lisa Sheree's Photo Gallery
I have a 1991 Toyota pickup. The dash lights behind the steering wheel do not work. The dash lights in the stereo and heater controls do work however. We already tried replacing fuses but that did not work. I assume this means the bulbs are burned out. Has anyone else had this problem? How do I change these bulbs out; how many are there; and what size are they? This problem is very frustrating since we can't see our spedometer at night. Help please.
Lisa Sheree is offline   Reply With Quote
Old 02-24-2005, 12:35 PM   #2 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Do the other lights on your dash work (ie turn signals, check engine) ? If so, it might just be the bulbs. There are 4 screws that old the dash around the instument cluster. Two are recessed in holes above the guages. The other two are one on each side of the steering column. Then there are 4 more screws holding the instrument cluster (easy to see with dash off). I have not been able to find the bulbs anywhere but Toyota. The screw in/out of the back of the instrument cluster. There should be 2 bulbs for night illumination.
If the bulbs are not bad, it may be the headlight switch not sending the signal to the dash but still operates the headlights.
Good luck.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline   Reply With Quote
Old 02-24-2005, 12:48 PM   #3 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
I think it may be the bulbs, most are #194 bulbs for illumination.
The hard part may be dealing with the speedometer cable when removing the cluster.
CraigW is offline   Reply With Quote
Old 02-24-2005, 01:13 PM   #4 (permalink)
Idaho Native
My other lights do work, it's just the illumination lights. Where can I order #194 bulbs? Know a good online store?
Old 02-24-2005, 04:04 PM   #5 (permalink)
View Tim Stewart's Photo Gallery
You can get #194 bulbs anywhere they are marked on the package. If you want a online parts store visit www.capitaltoyotalexusparts.com
Tim Stewart is offline   Reply With Quote
Old 02-24-2005, 08:30 PM   #6 (permalink)
View Smoke's Photo Gallery
The factory bulbs on my 94 are 158 and are avaiable at most parts stores. They are the slide in style. I find the 194 to be a lot brighter but will work!!
94 Toyota PK Ex-Cab 3.0 4X4 Auto
Smoke is offline   Reply With Quote
Old 02-25-2005, 12:56 AM   #7 (permalink)
Stop buying garbage
peterng's Avatar
View peterng's Photo Gallery
Canada tail lights
The first thing to check when your dash lights dont work is your tail lights. It is a safety nechanism in the circuit that if for some reason your tail lights go out (independant of the parking lights), your dash lights go out to tell the operator that there is a problem with the tail lighting which is a problem you wouldnt want to find out about the hard way.
Beyond that, could be bulbs, or it could be a short that is making the dash think that the tail lights arent working.
Could be simple (which taking the dash apart is not) but I just wanted to add the tail light thing to this post.
Pete
peterng is offline   Reply With Quote
Old 02-25-2005, 10:43 AM   #8 (permalink)
Idaho Native
Tail lights do work
My tail lights do work. So how do I check if it's a short making the dash think the tail lights are working without tearing the dash apart?
Old 02-25-2005, 09:11 PM   #9 (permalink)
Stop buying garbage
peterng's Avatar
Canada maybe
Lisa,
Again, I'm no expert, I have enough experiene with this so that I now have more questions than I had before After having thought about it, I'd say that if there was a short, you'd be blowing fuses. If there is a blown fuse, and when you replace it it immediately blows the fuse, then there is a wire that has power to it that is shorted out. The other side of the situation is a bad ground. Either way, the only way to diagnose it is to have a wiring diagram that shows the dash wiring. You'll see that on there are 4 terminals at the back of the instrument cluster. the terminal on the far left (left of the steering wheel looking forward has a wire again on the far left. That is the one that delivers power to the cluster. Once you've got the cluster out. You can flip it over and actually trace it's path around and see how it delivers power to 2 lights in back there. So the short and skinny of it is you have to get the cluster out to test. Check the bulbs. If not then you can turn the parking ligts on, check with a volt meter to see if power is at the terminal. very simple procedure, getting the dash apart was the tought part. if there is power therem you can test with an ohm meter for continuity on the back of the cluster itself to make sure power is passing through bulb housings and so forth. Someone with a very basic understanding of how to run an electrical tester and read a wiring diagram can go through this.
All that said, I have no dash lights My tail lights went out, and the fuse box was blowing fuses. I traced the power line forward from the tail lights, tapping into it every so often and delivering 12 v from a raw wire on the battery to try to find the short. I know the short is in behind the dash somewhere. So I bypassed the dash and ran power off the fuse panel straight to the tail lights, giving me no dash lights. The parking light switch send power to a relay which switches and sends power through the fuse box, then through both bulbs in the instrument cluster, then the tailight power wiring leaves the cluster, runs in behind the dash, comes out under the engine control module under the glove box to a junction under the passenger seat, then pretty much straight back to the tail lights.
What I don't totally have figured out is that there is a safety mechanism, somehow if you don't have power in your tail lights, the circuit shuts down and turns your dash lights off. Your problem may be related to that, I don't have mine figured out so I'm not one to say I guess.
Did both dash lights go out at the same time/ or was half the dash lit, and then all the lights went out? One of the dash lights os right behind the fuel meter, the other is behind he left side of the speedometer meter on my truck. My right bulb had always been burne out. I'd beat on the dash with my fist and sometimes it would come back on. That may be related to my problem.
If both lights went out at the same time, there is a very small chance that both bulbs blew at the same time naturally.
Check to see if there is a fuse just for the dash lights, I don't think there is, I think it is tied to the tail light fuse.
If the fuses are fine you've really got to get the instrument cluster out to check it out, and having someone around who knows what they are looking at would help.
Probably didn't help a lot but that's all i know about that.
Pete
Old 09-29-2005, 04:18 PM   #10 (permalink)
View dpence's Photo Gallery
I recently purchased a '91 and had to replace a bulb in the instrument panel cluster. CraigW is correct, the bulbs are #194g (the g is for the green coating) and the speedometer cable is a pain. I removed the cable from a couple of clips on the engine side of the firewall to get enough room to get my hand behind the panel and remove the cable. Hooking the cable back up is no easy task either.
dpence is offline   Reply With Quote
