93 pickup, starter or solenoid? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 03-02-2005, 04:40 PM   #1 (permalink)
View sting72's Photo Gallery
I have a 93 pickup, 2.4L, with a starting problem. It started a few months ago, attempts to start the truck would result in the solenoid just clicking. I was told that the ignition switch will cause this, I change it and for a few weeks my truck started fine now it's up to it's old tricks again. I figure it's either the starter or solenoid and at about $100 each, I would rather change only the part that needs changing. I already removed the starter once and the local NAPA tested it and said both parts are okay. Of course it wouldn't act up on the bench. Any ideas which part is giving me my problem?
sting72 is offline   Reply With Quote
Old 03-02-2005, 07:16 PM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
You can fix it yourself if you can get the starter off. The plunger and the contacts may be in good enough shape to clean up. Very simple.
CraigW is offline   Reply With Quote
Old 03-02-2005, 09:09 PM   #3 (permalink)
View Sidney's Photo Gallery
7 starter repair sites:
http://www.off-road.com/4x4web/toyota/tech/starter/ -
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
http://www.toyotaoffroad.net/afertig...rterrepair.htm
http://www.4x4wire.com/toyota/maintenance/starter/
http://www.barneymc.com/toy_root/techneek/starter.htm
http://perso.wanadoo.fr/adherence.4x4/start_bj.htm
http://www.automotiveforums.com/vbul...d.php?t=166530
Starter contact kits:
Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT)
Toyota # 28226-72080 (8808-9108)
Toyota # 28226-16130 (9108-9308)
Toyota # 28226-55050 (9308-9511)
Toyota # 28226-70040 (9308-9511)
Toyota # 28226-72040 (motor side if needed)
Toyota # 28226-72010 (8808-9511)
Toyota # 28226-74070 (9108-9511)
For others besides 22R series:
Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130,LN108,112,85..4FC)
Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and gasket)
Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70)
Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80)
Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#)
Starter contacts only:
Wilson’s Electric # 45-29-652
Starter brushes:
AC Delco # D762
GP Sorensen # 255048
Standard # JX-117
Whether your starter uses two rectangular types or one rectangular and one crescent you can substitute with two squares or one square and one crescent so any of the above part #'s for those kits will be the right ones,or about half of the auto electric shops in your local yellow pages would sell aftermarket contacts for only $5 each or the pair.
If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver.
For carbon brushes R&R:
http://www.4x4wire.com/toyota/mainte...nator_brushes/ http://www.toyotaoffroad.net/afertig...torbrushes.htm
http://perso.wanadoo.fr/adherence.4x...nateur_kzj.htm
http://www.automotiveforums.com/vbul...d.php?t=166525
http://www.bitwalla.com/cruisers/art...lternator.html
http://www.barneymc.com/toy_root/tec...c/altrnatr.htm
For decoding the dashboard lights:
http://www.powerbase-auto.co.uk/alternator_faults.htm
http://members.1stconnect.com/anozir...alternator.htm
Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles.
Toyota alternator Brushes with holder:
Toyota # 27370-35060=$29
Alternator brush only (qty:1 brush unless otherwise stated):
AC Delco # E724,E731 (side wire and concave tip)
Ace Electric # DA-61 (brush only),S-5367 (brush holder)
Beck Arnley # 178-1669 (side wire and concave tip)
Beck Arnley # 178-1376
Borg Warner # X580 (side wire and concave tip)
Canadian Tire # 19-2050-6=$4.49/pair
Daihatsu # 27370-87302-000
Daihatsu # 27371-63020-000
Daihatsu # 27371-87501-000
Daihatsu # 27371-70300-000
Echlin # E601=$8.16/pair (UAP/NAPA)
Echlin # ECHE601
Echlin # EC480
Echlin # ECHE480
GP Sorensen # 255047 (side wire and concave tip)
GM # 94123056
GM # 96054118
Honda # 31144-PD1-004=$9.72
Honda # 31144-PD1-0040
Honda # 31144-PD1-0030
Honda # 31150-PR7-A01
Honda # 31150-PTO-003
Hino Industries # 021660-0390
Hino Industries # 021660-0510
Isuzu # 8-94123-056-0
Isuzu # 8-97032-308-0
Isuzu # 8-97032-310-0
Mazda # 021660-0390
Mazda # 021660-0510
Mazda # KL47-18-W75
Mileage Plus # E601SB
Mitsubishi # MD604474
Mitsubishi # 21660-0510
Niehoff # WA571 (side wire and concave tip)
NipponDenso # 021660-0390
NipponDenso # 021660-0510
Standard # JX-116 (side wire and concave tip)
Subaru # 021660-0390
Subaru # 021660-0510
Suzuki # 31631-82610
Suzuki # 31656-82611
Suzuki # 021660-0510
Toyota # 27370-42010
Toyota # 27370-75060
Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip)
Toyota # 27371-70300=$5.20 (9105-9511)
Toyota # 27371-76004-71
UAP/NAPA # MPEE601SB
Victory Lap # FAX57=$4.49/pair (Canadian Tire)
Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40)
Specifications:
Length=15 mm
Width=7 mm
Thickness=5 mm
Lead length=49 mm
Sidney
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 243 000 KM
Sidney is offline   Reply With Quote
