1990 Pickup-Ignition Switch? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 04-22-2005, 05:46 PM   #1 (permalink)
View Gbob17's Photo Gallery
Hey, I have a 1990 Toyota 22Re 4wd pickup. My ignition switch is bad and I am using two screwdrivers to start my truck. I am disconnecting the ignition lead from my starter and am placing a screwdriver in its place, I then connect another screwdriver from the positive terminal lead(on my starter), and touch it to the first screwdriver to start my car (bypassing the ignition switch). The question is how do I remove and replace my ignition switch?
Read further down!
Gbob17 is offline   Reply With Quote
Old 04-22-2005, 06:20 PM   #2 (permalink)
Any help would be appreciated
Old 04-22-2005, 07:14 PM   #3 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Are you sure it is your ignition switch ? It is pretty straight forward removing from what I remember. There is the key tumbler that removes and then there is the ignition contacts. The contacts sometimes just need to be cleaned. Also, you may think it is the ignition and it turns out to be something else.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline   Reply With Quote
Old 04-22-2005, 07:27 PM   #4 (permalink)
Well, I replaced the starter three times, checked my connections and replaced my positive/ground cables(They were bad), replaced alternator(It was bad), replaced my battery(Terminals melted on trail), and checked for power everywhere with a digital multimeter. I found that I am not getting power(sometimes, its hit and miss) to my starter from the ignition lead. What else could be causing this bad connection to the lead and how do I fix it.
Old 04-22-2005, 08:53 PM   #5 (permalink)
View Smoke's Photo Gallery
Clutch or neutral safety switch!!
94 Toyota PK Ex-Cab 3.0 4X4 Auto
Smoke is offline   Reply With Quote
Old 04-22-2005, 08:56 PM   #6 (permalink)
Both, the clutch activates the switch, but there is also a neutral switch that allows you to bypass using the clutch. They do the same thing.
Old 04-22-2005, 10:12 PM   #7 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
On my 90 4Runner AND my 87 truck, it matters not whether you are in gear or in neutral. The clutch MUST be depressed to engage the starter. The neutral safety switch is for automatic transmissions. There is a switch on the dash that bypasses the clutch switch. My buddies 4Runner has a hit and miss clutch switch. We wound up bypassing it, since we generally know to push in the clutch before we start anyway. I would check voltage on both sides of that clutch switch and see if it's the problem.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline   Reply With Quote
Old 04-22-2005, 10:13 PM   #8 (permalink)
texas12's Avatar
The reason I asked above about why you think its your ignition is because I probably have the same problem as you. It's not the ignition, BUT.........I don't know what the problem IS.
Let me see, sometimes you go to start your truck and all the light come on but starter does not crank. Sometimes works just fine. Hit or miss, hot or cold.
I am an electronic technician by trade and this one has been driving me crazy. The starter solenoid is only getting about 7v when the problem occurs. That is not enough to push the plunger out to crank the engine. WHY? I don't know but I took voltage readings between the ignition and the starter, it is somewhere in between.
What I have done is install a manual starter push button. It is installed in the hole for the dimmer switch. I ran a wire from battery (+) to one lead of the switch and a wire from the other lead to the starter solenoid. Push the button and the engine will crank, even if the key is not in the ignition. However, it will not start unless the key is in the ON position.
I thought it was a grounding problem and have run an extra ground from the battery to the ECU to the ECT to the fuse box and over to the alternator. No help.
Haven't had much time to look at it lately and the starter button makes it less urgent. Let me know if you figure something out.
Old 04-22-2005, 11:27 PM   #9 (permalink)
texas12's Avatar
Hey Bob,
Just seen your post. I have and an auto trans....no clutch switch. Checked neutral safety switch (actually had it jumpered) and that is not it either.
Anyone else wanna take a stab?
Old 04-23-2005, 01:34 AM   #10 (permalink)
Young Buck
ElmerFudd's Avatar
View ElmerFudd's Photo Gallery
Try your starter relay, here's a diagram listed at Autozone.
http://www.autozone.com/servlet/UiBr...3d80160506.jsp
90' Toyota HTP Pickup 22RE 3" Body Lift Breathin K&N with 31" Sneakers.
ElmerFudd is offline   Reply With Quote
Old 04-23-2005, 12:19 PM   #11 (permalink)
alltrac165's Avatar
^oh yeah, the relay, good idea. check that too
Bob Raby
Santa Cruz, CA
Old 04-23-2005, 12:28 PM   #12 (permalink)
texas12's Avatar
My book mentions a clutch start relay, but I have an auto. Is there a starter relay for an auto? Where?
Old 04-24-2005, 12:04 AM   #13 (permalink)
alltrac165's Avatar
this is from the link posted by ElmerFudd
The starter relays on most of your Toyota trucks are located either in the relay block in the engine compartment or on the driver's side junction block. The cover for the relay compartments should be marked, "starter'' or the relay will have a part number with a suffix of 28300-XXXXX. Simply locate the relay, pull it out, and install a new one if needed.
Bob Raby
Santa Cruz, CA
Old 04-24-2005, 01:52 AM   #14 (permalink)
Young Buck
ElmerFudd's Avatar
I've rebuilt relays.. it's really not hard, they're really very simple. There's a current run to the relay causing an electromagnetic field that draws one contact into the other.. on every relay I've had to repair the contact that is drawn by the electromagnet is missing a bead of solder that makes the contact. If you have any experience with soldering, or know anyone who does it's easily repairable.
Old 04-24-2005, 04:27 PM   #15 (permalink)
texas12's Avatar
I read that the first time it was posted. What I am saying is that I have a '86 4runner w/ 22re and auto trans.......there is NO relay in either one of those spots marked starter or with that part #. There is the EFI main relay by the fuse box in the cab and the is only 1 relay in the engine compartment but it is labeled HEAD and does not have that part #.
So, the question is: Does an auto trans, 22re have a starter relay? If so, where.
