92 pickup low idle
my pickup has been idling at approx 500 according to the tach in the dash...i cannot figure out what is causing it...also is it better to advance your timing a little more than the recommended 10 degrees? i have new ngk wires and plugs, new distributor, new cap and rotor, new fuel filter, and new air filter...no idea why it idles rough. i am missing one of the caps on the #6 wire that holds the wires on the distributor cap...maybe a problem? any response would be appreciated....thank you
