Engine Misses in 4th and 5 gear - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux. NEW!
Old 10-06-2005, 10:46 PM   #1 (permalink)
View Blakbat's Photo Gallery
Question Engine Misses in 4th and 5 gear
Does anyone know why my v-6 88 4x4 would run fine through third gear and once in 4th, and the RPMs are under 2500, the engine would run rough. It is really baffling and I want to fix it. Having it miss in irritating to say the least. When in 4th, rough, shift to third and the RPMs rise to over 3000, it smooths out. Any Ideas?
Jeff
Blakbat is offline   Reply With Quote
Old 10-07-2005, 12:00 PM   #2 (permalink)
View smasheromalley's Photo Gallery
Possibility that it could just need a tune up. plugs/wires/cap/rotor
It takes more horsepower to move a vehicle in 4th gear than it does in 1,2, or 3rd gear. This requires you to use more pedal. More pedal puts more air and fuel into the cylinders. More air and fuel means higher cylinder pressures. Higher pressure in the combustion chamber creates higher resistence between the spark plug gap. Higher resistance means the spark is more likely to find another path to ground like down some carbon tracks or arc through a bad wire.
Hmmm, thats a theory...
Does it miss if you accelerate hard through low gears?
'87 1ton dually C/C
injected 22-RE 4-speed 4x2
smasheromalley is offline   Reply With Quote
