82 Toyota pickup 4x4 - steering problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux. NEW!
Old 10-11-2005, 07:44 PM   #1 (permalink)
View Kiijo's Photo Gallery
I've got a problem with my steering. Most of the time there is no problem, but at certain speeds (~35-40mph) I start to get pretty harsh shaking in my steering wheel. I've asked around a little bit and someone suggested that it might be a problem with the "shim dampener", is there such a thing? If so, is this the problem, and what needs to be done to get it fixed. Thanks!
Kiijo is offline   Reply With Quote
Old 10-12-2005, 10:13 AM   #2 (permalink)
View smasheromalley's Photo Gallery
Sounds like wheels out of balance to me. No big deal. Any tire store should be able to balance them.
Also check for mud to be caked and dried in the inside diameter of the wheel. This will also throw the wheels out of balance. Get under the truck with a screwdriver and scrape the dried mud off the inside of the rim. You might have to take the wheels off to get it all out.
'87 1ton dually C/C
injected 22-RE 4-speed 4x2
smasheromalley is offline   Reply With Quote
Old 10-15-2005, 07:48 PM   #3 (permalink)
Pipe Welder
banshee35's Avatar
View banshee35's Photo Gallery
check your king pin bearings asap. They'll give you the death wobble if they're wore out.
"Price reflects quality- You get what you pay for!"
banshee35 is offline   Reply With Quote
Old 10-17-2005, 02:03 AM   #4 (permalink)
TOYO-MAN
View sonofmayhem's Photo Gallery
i had grease&gunk build up on my rim, and that caused it to not go over 60, but now 70+ it shakes!?
85, lifted and ready to rock!
sonofmayhem is offline   Reply With Quote
Old 10-17-2005, 12:58 PM   #5 (permalink)
View maxpower_hd's Photo Gallery
I had an 84 where the "u-joint" in the steering column was worn. It's about a $100 part but not too bad to change. It's also easy to check. Just have someone jerk the steering wheel back and forth while you look at the u-joint under the hood. You will easily see the play. That fixed it for me.
Good luck.
maxpower_hd is offline   Reply With Quote
