22r upgrade - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 6 Old 01-11-2006, 05:00 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
22r upgrade
I'm planning on upgrading my 22r engine, im not sure what year it is, just know that its a 22r. Im on a tight bugget too, so i was wondering if you guys can help me out. I want better performance but i don't know who makes good performance upgrades for 22r's. All i need is pistons, head, and cam shaft. Also what are good ratios, because i have no idea. Also any good sources on the net you guys can lead me into. I don't know if this was very clear, but if you guys need more details i'll try my best to explain ....thnx.
04camcr is offline
post #2 of 6 Old 01-11-2006, 08:08 PM
Quoted: 0 Post(s)
leave the motor stock, swap a efi on to it. its thew best value for the money. go to junkyard and pull a stock efi of a 22re 85 -90
brownbagg is offline
post #3 of 6 Old 01-11-2006, 08:36 PM
Offical Truck Nut
1bad2WD's Avatar
Quoted: 0 Post(s)
best bang for buck
i would leave it stock and upgrade to a weber carb , I picked up about 15 horses and it set me back $379 and it only takes about 20 minutes to install
2002 Tundra V-8, cab TRD, limited 130,000
2002 Tacoma Regular cab 52,000
1bad2WD is offline
post #4 of 6 Old 01-19-2006, 09:04 AM
1986 Toyota 4x4
Quoted: 0 Post(s)
hmmmm.... What's involved in adding the efi? Don't you need ecu, injectors, fuel pump, I heard you even need the fuel tank. I'd love to hear more.
"You know you're on your own path, when the branches are hitting you in the face." - Don Gillis, UPEI Engineering Professor
Powderhoundin is offline
post #5 of 6 Old 01-19-2006, 12:01 PM
Offical Truck Nut
1bad2WD's Avatar
Quoted: 0 Post(s)
swap
to do it yes you will need everything engine bay wiring, ecu fuel pump and a good bit of down time.
1bad2WD is offline
post #6 of 6 Old 02-22-2006, 01:35 PM
1 of 1
82prerunner's Avatar
Quoted: 0 Post(s)
I suggest 22r block / 20r head (flows better) / header/ mild cam/ weber carb to start on a budget. Stay simple, you won't regret it. There are of course many other options including dual side draft mikunis or belt driven supercharger/carb setup. Check out the 200+ normally aspirated goodies at www.lcengineering.com ( that's LCENGINEERING) Nothing against EFI except computerizing unecessarily & it's a truck that may be going through lots of off road stuff. EFI kinda touchy for that sort of fun IMO, better for strictly street situation.
82prerunner is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
