switching 1-wire O2 sensor with 2-wire... - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 3 Old 03-13-2007, 08:40 PM Thread Starter
Quoted: 19 Post(s)
(Thread Starter)
I want to change out my 1wire with a 2 wire sensor that i've had laying around. the 2 wires are blue and white. which wire do i need? it's for an 86 22r.Also, what if i don't connect the sensor? does a light turn on in the dash? does it even have an ecu? Ihear this "brrrrr" sound from the carb.How do i get rid of it? it doesn't seem to affect driving when it goes off.
sc2dave is offline
post #2 of 3 Old 03-14-2007, 09:42 AM
myyota's Avatar
Quoted: 0 Post(s)
I would recomend that you use an oem replacement and nothing else, if your truck is carbed it still has a computer that operates the emissions stuff, so the 02 sensor is needed to help with the air fuel ratio, it works a little different in a carbed than it does in an efi truck, but still the same idea.
86 Toyota 4Runner
Gathering parts, getting ready to build it.
myyota is offline
post #3 of 3 Old 03-14-2007, 06:49 PM Thread Starter
Quoted: 19 Post(s)
(Thread Starter)
I've had this one already,that's why i want to use this one,instead of buying another. I'm not even sure it needs it. Is there a check engine light on these trucks? Also, what makes that "brrrrrr" sound
sc2dave is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
