Help DIY clutch master cylinder bleeding
I need some help. I am replacing with new/rebuilt(Autozone), both my clutch master cylinder and slave cylinder on my 86 22r 2w drive truck. I am having one hell of a time trying to get fluid thru my lines(pumped clutch pedal over 100 times,still no luck, but mast clutch cylinder seems to work fine!!?????) from the master to my slave cylinder. My lines are clean and I am pumping and bleeding the holy crap out of the system but all I am getting out of my slave is alittle air but no fluid. It is driving my absolutly nuts. Several years ago I went thru this and ended up having to rotate my slave cylinder upward so as to make the bleed nipple point upward(to remove air bubbles) and then I gravity bleed the system. That eventually worked and did the job. Now I cannot for the life of me get fluid down to the slave and its driving me NUTS. Anyone with good experience with this procedure on these old Toyota's would be much appreciated! I have been DIY ing on cars for 40 years and I am at my wits end. Help! anybody.....
