Bvsv - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 3 Old 10-04-2007, 06:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Bvsv
i have an '88 22R 2wd carburetor. there is a BVSV on top of the intake manifold toward the front of the vehicle on the driver side of the coolant outlet. it has two vacuum lines that are used in controlling the EGR valve.
where can i find a new BVSV? mine snapped off. the plastic was pretty old. i'd rather not use one from a junk yard because i'd be worried about it suffering the same fate, but i haven't found a website that sells these.
phburks is offline
post #2 of 3 Old 10-04-2007, 06:18 PM
Quoted: 2 Post(s)
This valve controlled by coolant temp?
Have you tried local autoparts stores, the part should not be that uncommon.
Or try website such as www.rockauto.com. Look under Toyota/Pickup/Emissions.
toyomoho is offline
post #3 of 3 Old 10-04-2007, 11:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
thanks a million toyomoho. rockauto has it, but they call it an emissions vacuum valve instead of BVSV: http://www.rockauto.com/catalog/rafr...&parttype=4980
yeah it's controlled by coolant temperature. i took it to autozone but they couldn't find it in their system. same with advance auto. anyway, i can order one now.
thanks again!
phburks is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
