22r Aftermarket Carbs - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 7 Old 02-21-2008, 12:06 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
20R and 22r motors pull in about 110-160 Cfm.
I cannot find any 110-160 CFM after market carburetors that run with this low cfm besides webber... anyone else have any luck?
80_pickup is offline
post #2 of 7 Old 02-21-2008, 12:23 AM
DCM
One with the farce
Quoted: 5 Post(s)
I don't know where you're getting your info, but here are some carb cfm flow numbers. Keep in mind Toyota engineers probably did their homework.
Carb Info:
Carb Flow
Stock 20R Aisan 190 cfm
Stock 22R Aisan 326 cfm
Weber 32/36 325 cfm
Weber Dual 38 390 cfm (Downdraft)
Weber Dual 40 405 cfm (Downdraft)
Dual Mikuni 40 PHH 724 cfm (181 cfm per tube)
Dual Mikuni 44 PHH 844 cfm (211 cfm per tube)
'92 ST185 All trac turbo
'91 Cressida
'72 TE27
DCM is offline
post #3 of 7 Old 02-21-2008, 12:24 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
HMmm, i must of done math wrong i got my information from here
http://64.233.167.104/search?q=cache...nk&cd=19&gl=us
post #4 of 7 Old 02-21-2008, 12:36 AM
DCM
One with the farce
Quoted: 5 Post(s)
Yeah I can see how you got that, but don't forget that the calculator is generic, not engine-specific. There's a local guy (local to me, anyway) who has a holley 390 cfm bolted to an offenhaeuser dual-plane intake on his 22R...and he can light up his 35's. So tuning has a lot to do with it. THe factory specs are there so the engine can live for 100's of thousands of miles, and the designers didn't factor high performance into the picture.
'91 Cressida
'72 TE27
DCM is offline
post #5 of 7 Old 02-21-2008, 12:39 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Noob question but what is a dual-plane intake.
I want to buy a weber carb, or any other aftermarket carb, Only reason I am leaning twords weber is because they have a conversion kit. Im afraid i will get a too big of a cfm for my motor.
post #6 of 7 Old 02-21-2008, 12:55 AM
DCM
One with the farce
Quoted: 5 Post(s)
Okay, an intake manifold can be single plane or dual plane, and I'll just paste a bit of info here, maybe skim through it and see if it makes sense.
Single-Plane Versus Dual-Plane
A single-plane intake manifold is the simpler of the two layouts, connecting the plenum under the carburetor with runners leading fairly directly to the cylinder head ports. The two-plane design appears more convoluted with a divided plenum with one side's plenum dropping down lower than the other, and the respective high or low runners routed alternately to the left and right cylinder heads of the engine. Most any motorhead can distinguish a single-plane intake from a two-plane just by looking at it, however, surprisingly, few know what the difference is conceptually. Let's take a look at dual-planes first.Though many early OEM engines used single-plane manifolds, auto manufacturers overwhelmingly favor the two-plane design. Looking at a two-plane, with some runners crossing over from side to side, a two-level divided plenum, and the obviously greater complexity in casting such a piece, we have to ask why the manufactures would go through the trouble. A single-plane open-plenum intake would obviously be easier to design and cheaper to build. Why bother with a two-plane? The design has many advantages.
As a general rule, it has been found that a two-plane intake improves low-rpm response, torque production and idle quality. These are pretty worthwhile characteristics, so it's worth exploring why this is the case. Runner length plays an important part in the rpm range at which an induction system "tunes-in," taking advantage of the natural pressure wave pulses in the intake tract to provide a greater charge density in the cylinder, and therefore more torque and horsepower. As a general rule, longer runners "tune" at a lower rpm range, while shorter runners favor the upper end of the rpm band. Similarly, it has been found that a smaller plenum also favors power production lower in the rpm range, while larger plenums are more inclined to boost the top-end. In these two characteristics, the dual-plane has natural advantages over the single-plane, but there is more. Runner cross-sectional area also plays a part. Smaller runners necessarily result in higher air-stream velocity in the manifold, which improves cylinder filling by improving inertia effect by virtue of the energy contained in the moving gasses. A dual-plane design generally features runners of a smaller average cross-sectional area than a single-plane, lending itself to higher velocity at low rpm.
All of these characteristics provide a low-speed advantage in their own right, but the effects are compounded when the carburetor is considered. Taken as a group, a smaller cross section, longer runners, and a smaller plenum create a system that is more responsive at transmitting the induction signal from the cylinder to the carburetor booster. This improvement in signal by the air stream connecting the cylinder to the carburetor improves the carburetor's metering response, and aids in low-speed atomization.
DCM is offline
post #7 of 7 Old 02-24-2008, 11:07 PM
Benwill1
benwill1's Avatar
Quoted: 0 Post(s)
They will be just fine on a stock engine
'80 Toyota street/mud bog racer-22r/20head/bigssvalves/38mm dges Weber/header/Weisco pistons/stock bore,crank,rods/Scneider cam/4.30 gears/88(wider)rear/locker/36" tires
'84 4x4 extra cab/weber/header/Crane-12cam
RARE '85 4x4 auto/EFI. Not drivable(rod knock, missing parts)
benwill1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
