How to check cooling fan clutch? - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 3 Old 05-10-2008, 07:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Im just wondering if my cooling fan is working properly. Ive got a 1988 22r and ive never seen the motor run without the fan spinning even in cold weather. I thought the fan wasn't supposed to turn until the motor heats up. Also is the fan supposed to quit spinning when you reach highway speeds? And is there a way I can test my clutch? Thanks
mikes451 is offline
post #2 of 3 Old 05-10-2008, 07:29 PM
Senior TN Member
verlaryder's Avatar
Quoted: 220 Post(s)
The fan is supposed to spin continuously, but at relatively low RPM except in when extra radiator cooling is needed. Conditions when the fan should roar loudly include creeping along in bumper to bumper traffic and going up hills in hot weather. In really hot weather (around 100 degrees F) the fan may roar more or less continuously.
To check the fan clutch, open the hood in the morning before starting up the engine. The fan should spin with considerable resistance. If the fan free wheels with no resistance then the fan clutch is bad. But they rarely go bad. A symptom of a bad fan clutch is the engine temperature gauge rising up to the 3/4 mark or beyond in bumper to bumper traffic and going up hills in hot weather.
verlaryder is offline
post #3 of 3 Old 05-11-2008, 10:57 AM
Quoted: 0 Post(s)
What verlaryder said, mostly. It shouldn't take a great deal of effort to turn the fan when the engine (and everything around it) is not warmed up. But, it should take effort. If it spins easily, or if it's impossible to spin, then the fan clutch needs to be replaced.
It's not uncommon for an old fan clutch to fail, either, but they usually do so by seizing up. I had to replace the fan cluch on my '88 4Runner for exactly that reason. Just driving slowly around a parking lot created a deafening roar from the fan, because it was running at crankshaft speed (seized fan clutch, no slipping at all).
grungebucket is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
