Intake HP increase questions - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 25 Old 10-12-2008, 11:00 PM Thread Starter
1987 Toyota 4runner
Joshua Ziegler's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I have been reading through several forums related to HP increases with the 22re and found that 1)swaping sides with the battery and intake or 2)replacing the factory plastic peice going from the intake to the airfilter with a larger 3" peice are some great and cheap HP increases.
Here are my questions: Has anyone tried this yet? Has it helped? I saw a pic on another forum where the guy had a U shaped peice going straight to the AFM into a cone shaped breather on the passenger side but the AFM wasn't plugged up. Apparently you can bypass the AFM by hooking up the fuel pump to a relay? Is this true? And would it have any effect on the ecu or throw any codes by doing this?
Joshua Ziegler is offline
post #2 of 25 Old 10-13-2008, 05:05 AM
Resident asshole
Flashmn's Avatar
Quoted: 2 Post(s)
You need the AFM for engine load sensing, if you bypass it, engine wont work properly. Also hp increase from a filter is neglible.
Flashmn is offline
post #3 of 25 Old 10-13-2008, 10:24 AM
Quoted: 0 Post(s)
you need the AFM and i dont think you would ever feel an increase from an intake....i say that even though i have one
84prerunner is offline
post #4 of 25 Old 10-13-2008, 10:51 AM
Senior TN Member
Krusty's Avatar
Quoted: 0 Post(s)
any gain - which is UNLIKELY-- would be so slight, it wouldn't be worth the efforts !!!!!!
also found on TinBenders.org
Pirate4x4.com
92 22RE x-cab 4x
and a 86 22RET as a 'truggie' rock crawler
pics in photo gallery-- Krusty
Krusty is offline
post #5 of 25 Old 10-13-2008, 06:20 PM Thread Starter
1987 Toyota 4runner
Quoted: 0 Post(s)
(Thread Starter)
I was also reading where one guy cut a 3" hole in the side of the airfilter box then ran a 3" pipe from the box to just inside of the grill so it would suck in the cool air from outside of the 4runner as opposed to the hot air under the hood. What do ya'll think about that?
post #6 of 25 Old 10-13-2008, 06:42 PM
Quoted: 0 Post(s)
same...marginal
post #7 of 25 Old 10-14-2008, 07:18 AM
Resident asshole
Flashmn's Avatar
Quoted: 2 Post(s)
a 4Runner gets is air from the bumper or grill in stock configuration. Even my 87 hilux got its air from the headlight area. So my opinion is waste of time.
Flashmn is offline
post #8 of 25 Old 10-14-2008, 10:22 AM
Quoted: 0 Post(s)
if your looking for more power id get a cam and header with a 2 1/4" pipe.
that will give you a very noticeable improvement.
post #9 of 25 Old 10-14-2008, 11:27 AM
Senior TN Member
Krusty's Avatar
Quoted: 0 Post(s)
if you want something more----- drop in a 4.3 and be done with it !
Pirate4x4.com
92 22RE x-cab 4x
Krusty is offline
post #10 of 25 Old 10-16-2008, 01:08 AM
Quoted: 0 Post(s)
I posted a few months ago about HP gains with keeping decent mileage. head / intake / exhaust manifold
so i did the gasket match porting on the intake manifold and put in a engnbldr 268C cam, stuck with stock ehaust manifold but went 2 1/4" after that. I really liked the gains i got. I am still on the first tank of fuel so not too sure what the milage is but the power is better. Oh yeah this is all on an 86 pickup with a 22RE. The cam works fine with the ECU. Nothing was done with the air intake...all stock.
tuckman is offline
post #11 of 25 Old 10-16-2008, 02:30 AM
yota44's Avatar
Quoted: 0 Post(s)
I have an 88 22re with a comp 260s cam, pacesetter header. 2 1/4 inch exhaust, flowmaster and the K&N cone filter kit (which im probably guna get rid of) . I never felt the actual gains since the truck has been like this since i got it, but i know i beat my buddies 22re's
88 Toyota 4X4 22re. Comp 260s cam, Pacesetter header, 2 1/4 straight piped, 50 Series Flowmaster, K&N cone filter adaptor, bunch of other useless shit
yota44 is offline
post #12 of 25 Old 10-16-2008, 03:10 AM
Quoted: 0 Post(s)
same as me, i have a downey EFI cam, header, intake, and 2.5" pipe with a flomaster. bought the truck with all that on it so i dont know how much they helped but from riding in other 4cyls and from what ive heard i think it does damn well for beign an auto
post #13 of 25 Old 10-16-2008, 05:30 PM Thread Starter
1987 Toyota 4runner
Quoted: 0 Post(s)
(Thread Starter)
My 4runner already has a mild upgrade on the cam. Not sure about the duration. It was already installed when I got it. Plus its bored out .20 with a 2" exuast and a turbo muffler. I also have the cat off of it and the EGR valve is blocked off. It has pretty good acceleration for a 22re but it has some trouble keeping its speed on the interstate going up hills. I was just trying to think of something else to sqeeze out some extra power.
post #14 of 25 Old 10-16-2008, 06:37 PM
Quoted: 0 Post(s)
do you have a tach?
i think my main problem holding speed is the gay auto, i can push it almost to the floor in OD at 2500rpm and hold my speed on flat ground or i can take it out of od and run 3,000rpm at like 1/4 throttle up hills no problem. they key for me is to be over 3,000rpm. If im running over 85mph (yes i can do it) it will stay in od up most hills becuase im at 3200+rpm.
post #15 of 25 Old 10-16-2008, 07:22 PM Thread Starter
1987 Toyota 4runner
Quoted: 0 Post(s)
(Thread Starter)
Yea, my tach reads around 2,800 rpms at 70 mph but its a 5 speed.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
