Pitman Arm Removal? - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 8 Old 07-14-2009, 12:27 PM Thread Starter
Creep
pokernod's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Pitman Arm Removal?
Im changing out the front end and seem to be having trouble getting the Pitman to slide off of its grooves on the steering box shaft. Ive done this a zillion times and have never had trouble before.
Besides the hydraulic "Jaws of Life" anyone have a few ideas. I say a few because I may not have the exact tool(s) needed, so a couple of alternatives would be nice.
pokernod is offline
post #2 of 8 Old 07-14-2009, 02:34 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 213 Post(s)
Just about any parts store will loan you one, you just have to leave a refundable deposit.
No THANKS necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 8 Old 07-14-2009, 08:02 PM Thread Starter
Creep
pokernod's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I have a giagantic slide puller that would work but its too long to fit under the truck. But If I had a large bolt with the same size threads (5/8 in fine) I could just put the air to it. I looked around the truck to see if there was one I could pull off and use but it got dark on me. I'll look through the haynes tonight and see if I can find one
pokernod is offline
post #4 of 8 Old 07-14-2009, 08:18 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 213 Post(s)
If you mean you're looking for a 5/8" fine thread bolt on your truck, stop looking, it's metric.
89 4Runner - stock
fourwd1 is offline
post #5 of 8 Old 07-15-2009, 11:51 AM
Corona is gone.
79Corona's Avatar
Quoted: 0 Post(s)
I'm wondering if a slide puller might damage the bearings. I believe you need this.
Bryan
86 Hilux LE (blue)
Other Toyotas : 79 Corona DLX sedan (Mint green), 89 Corolla DX sedan (wine), 88 Camry V6 LE sedan (blk), 86 Hilux std bed (wine), 82 Celica GT hatchback (bwn), 78 Celica GT coupe (slvr), 76 Corolla SR-5 coupe (wht)
79Corona is offline
post #6 of 8 Old 07-15-2009, 04:49 PM Thread Starter
Creep
pokernod's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Yea, thats what I usually use, But I dont know where it is. I was actually going to look for a machine thread bolt like that to put in the end of the one I have (take the slide and bar off) But Im glad you mentioned that, I didnt think about the steering box at the end of it all. If I couldnt find the bolt I would have probably jacked the truck up for slider room and messed it up. Guess Ill drive the trip to go get one.
Been off the wrench for a few years, LoL......Guess it shows.
But thats what forums are for right?
pokernod is offline
post #7 of 8 Old 07-16-2009, 09:31 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 213 Post(s)
I get away with improvising a lot, but the correct tools always make the job easier.
89 4Runner - stock
fourwd1 is offline
post #8 of 8 Old 07-16-2009, 08:57 PM
Supafly
Jayota's Avatar
Quoted: 0 Post(s)
Spray the threads with lube, tighten a pitman puller up, and give the arm a few good smacks with a hammar, repeat as nessesary.
Never met one I couldnt remove
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
