1986 22re wont stay running - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
View Poll Results: Think im right with the injectors?
yes 0 0%
no 1 100.00%
Voters: 1. You may not vote on this poll
post #1 of 3 Old 08-21-2011, 09:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
First a lil bit of back story
I bought the truck about a month ago for $400 defiantly needing work but mostly cosmetic.
Got the truck running great at the shop but on the drive home the bottem radiator hose blew and the truck overheated and now wont stay running
now the problem
i can spray carb cleaner into the intake and it will run great until that burns off then it shuts off.
if i keep the gas to the floor it will stay running but not above 1000rpm.
my guess was the injectors were shot but figured id ask here before blowing all my money
swvfd626 is offline
post #2 of 3 Old 08-22-2011, 11:29 AM
Banned
Quoted: 0 Post(s)
I don't see how overheating it would kill the injectors.
Why didn't you stop when the thing started heating up?
More likely, you did some damage to the engine, you might have bad compression on one or more cylinder. You should check compression and leak down.
As far as running on carb cleaner, anything you add that is highly volatile and highly combustible will tend to give it a bit extra. If your engine is on the very edge of destroyed, that might be just enough to get it to barely fire up.
Start by testing that engine's condition, not by replacing parts.
sonofa is offline
post #3 of 3 Old 08-22-2011, 10:19 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I woulda stopped but the coolent temp sensor must be bad cuz it wasnt reading hot.
i pulled the injectors today and all of them were about 90% blocked
all the cylenders had the right amount of compression and it wasnt blowing white smoke.
ive been workin an cars for a while now but this is all new to me...i aint never seen nothin like it
swvfd626 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
