Negative Battery Cable? where does it go. - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 7 Old 09-11-2011, 12:56 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
where does the negative cable connect to? i just bought an 85 truck not running for 200$ no neg cable. thanks
chugach is offline
post #2 of 7 Old 09-13-2011, 08:56 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 196 Post(s)
It connects to the Negative battery terminal.
And the other end connects to a bolt in the inner fender wall right by the battery.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 7 Old 09-13-2011, 09:25 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
That easy, no other connections? ill put a cable on tomorrow and see if this thing turns over or not!thanks
chugach is offline
post #4 of 7 Old 09-17-2011, 12:17 AM
wife 86 4x4 me tundra
Quoted: 0 Post(s)
hey fourwd1
hey fourwd, was wondering bout your answer, my 86, when we did the engine rebuild, i put my negative to the lower passenger side of the engine
block, is this ok, or should it be moved to the fender well, holy moly would this have a issue on my dim passenger headlight?
the goon i am
The BIG Goon is offline
post #5 of 7 Old 09-17-2011, 01:34 AM
Quoted: 0 Post(s)
the goon i am
I dont think it would matter unless your block and our bolt is painted. All your negative battery cable is doing is making your whole trucks frame and everything else metal that comes in contact with it the negative part of your electrical system. So then all you have to do is Hook up the positive of lets say a light to a positive cable running to the battery then the negative side of the light can be grounded to the frame.
For your light being dim, that could be from bad wiring connections anywhere in the lights electrical system. Have you tried switching the lights between passenger and drivers side to make sure its not the light itself?
dmc14 is offline
The Following User Says Thank You to dmc14 For This Useful Post:
The BIG Goon (09-17-2011)
post #6 of 7 Old 09-17-2011, 01:36 AM
Dave's
Quoted: 26 Post(s)
I haven't checked any time in the last decade or so but there used to be a heavy braided copper wire connecting the engine to the body. Possibly they now simply run separate wires from the negative post to both the engine and the body. But I'm sure both the body and the engine need to be grounded with the engine ground probably being the bigger wire due to the current draw of the starter.
Dave's is offline
The Following User Says Thank You to Dave's For This Useful Post:
post #7 of 7 Old 05-27-2012, 11:40 AM
FloridaAKM's Avatar
Quoted: 0 Post(s)
On my 88 4WD Toyota, the large negative cable goes to the engine block on the passenger side & a smaller wire to the fender next to the battery! Everything works as it is supposed to !
Everyday you wake up on the grass side of the dirt is a good one!
FloridaAKM is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
