Wiper circuit - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 3 Old 10-29-2011, 11:29 AM Thread Starter
ussfox's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Wiper circuit
Hey everyone,
I know I shouldn't have done it but i turned the wipers on this afternoon to clear some of this heavy snow off were having here in PA and wipers just stopped working. Fuse is good...no voltage at wiper motor. I have the electrical diagram book and it says the relay should be in the passenger kick panel. I see the emission relay as noted but not wiper relay. do I need to dig deeper under the dash? Sure could use some help on this. 86 shortbed,22r,4wd. thanks much
ussfox is offline
post #2 of 3 Old 10-29-2011, 10:51 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 280 Post(s)
IIRC it may be above the kick panel, you may have to remove the glove box for easier access.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is online now
post #3 of 3 Old 10-30-2011, 12:59 PM Thread Starter
ussfox's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I removed the glove box. Stuck my hand up behind the blower motor and there are no relays to be found. I wonder where it is?
Anyway I went back to the fuse panel and realized I was checking the wrong fuse. It was a blown fuse...I had a 10 amp in instead of a 15.
I appreciate the reply anyway...this isn't the first time you have helped me out.
ussfox is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
